[Skin] Shadow WQHD (DreamOS)
Shadow WQHD skin for Dream One, Two and Seven devices
WQHD skin has a resolution of 2560x1440
zombi wrote
Note about the skin:
My Shadow WQHD skin got a new license (this is also in the skin.xml and this is please note, if I notice that this is ignored I will no longer offer public update's and there will be no further skinupdate more or from me absolutely nothing more free for the general public.
license "This skin may not be changed or offered under a different name.It may only be used on Amlogic Dreamboxes with the DreamOS operating system."
If you want to have alternative screens etc. you can do this with styles and a styles_user.xml ,this is allowed and even wanted ,but a mod. of the WQHD skin or other adjustments in the skin is absolutely not wanted and this is stated in the new license to the skin.
The Shadow WQHD Skin is an extended version of the default WQHD in the new DreamOS and only usable for the Amlogic Dreamboxes which use the new Dreambox aio (All IN ONE).
It is like all my current skins not a GP skin (even if this is in the name) but GP Ready, which means there must be nothing of the GP installed the skin is default always in all Dreambox aio executable whether it is the original, Merlin, NN2 or...
Since this skin is a WQHD skin with a resolution of 2560x1440, it is mainly suitable for large TV devices, even small TV devices goes, it just depends on whether one is then not everything too small by the resolution, you just have to test it.
This skin has compared to the default WQHD many more plugins geskinnt, some screens are a little andersst than in the default and also he has certain extra info about extra converters and renderers that are not in the image directly inside.
Also, this skin no longer uses the gesammtPaket enigma2-plugin-skincomponents-extcomponents (this must also no longer be installed in old version, otherwise the skin is not installed) but individual enigma2-plugin-skincomponents where I have the necessary also attached here in the first post.
necessary dependencies to use the skin:
The enigma2-plugin-skincomponents attached here in the post must be installed to install the skin (without one of the packages, the skin will not be installed.
Manual installation:
Variant 1. download all deb packages to tmp and then install with telnet
apt-get update ; dpkg -i /tmp/*.deb ; apt-get -y -f install
Variant 2. load all deb packages to tmp and then install with a file browser or the media scanner
Install online:
- simply only the skin over the Addonbrowser of the GP4.2 under Enigma2 Skins as well as Gemini Skins to find to install/updaten click and start,it are loaded then all necessary packages with.
Customization of the designs and more:
Through the plugin Styles what it here: Styles to reload and where is also the support for the plugin you can customize some already default in the skin.
As the name of the plugin says, the look of the skin can be changed.
You can also create your own styles_user.xml if you are interested in the whole thing and put it in /etc/enigma2.
This user file will be shown in styles (if you have enabled them for the skin) and then you can add your own stuff.
With Styles you can use several color designs of the skin by default, many more and different screen views for certain plugins and much more.
Has thanked: 14363 times
Been thanked: 1661 times
Re: [Skin] Shadow WQHD (DreamOS)
Update: v1.0-r81 >>>>>(Online Update)..
Quote
New update:18.02.2024
- Font und Farbfix..
- Flat Infobars angepasst..
- interne Anpassungen an Screens..
- Primetime heute /morgen widget mit eingebaut in den Kanallisten wo dies vorher als festes Textlabel vorhanden war (das ganze schaltet sich jetzt dementsprechend um)..
Thx zombi
Mediaportal WQHD Skin Update: .02.06.24 v2.0-r5 >>>>>(Online Update)
- Adaptation to the current ShadowWQHD update
- minor internal adjustments
thanks zombi
Update: v2.0-r16 >>>>>(Online Update)..
New update:28.07.2024
- neues schaltbare MainmenĂĽ mit Namen EDM ,dies zeigt mit aktuellem EDM Plugin im HauptmenĂĽ die EDM Bild und Info Daten..
- internes..
Thx @zombi
Update: v2.0-r17 >>>>>(Online Update)..
New update:30.07.2024
- neue schaltbare Secondinfobar EDM Ansicht (alte wurde entfernt)..
- neue schaltbare Pluginbrowser Ansicht ,schaltbar wenn man EDM installiert hat..
- internes..
Thx zombi
Update: v2.0-r21 >>>>>(Online Update)..
New update:20.08.2024
- kleinere Änderung im schaltbaren ChannelSelection Layout "EDM Media NextEvent"..
- Hauptmenü Display Screen geändert (jetzt mit Icon und Uhrzeit im Display)..
- BluePanel Display Screen geändert (jetzt mit Icon und Uhrzeit im Display)..
- kleine interne Dinge..
Thx zombi
Update: v3.0-r4 >>>>>(Online Update)..
New Update: 01.11.2024
- Mediathek View Dream Anpassungen der Player ,diese sind im neuen Small Design was hier völlig ausreicht bei diesen Playern.
- TV Spielfilm View Screen angepasst an das neue Update..
- interne Anpassungen hier und da an den Screens da es noch kleine Dinge gab die mich störten ..
- Media library View Dream adjustments to the players, these are in the new small design, which is completely sufficient for these players
.- TV Spielfilm View Screen adapted to the new update..
- internal adjustments here and there to the screens because there were still small things that bothered me
Thx @zombi
Update: v3.0-r5 >>>>>(Online Update)..
New Update: 03.11.2024
- paar kleine interne Anpassungen..
- a few small internal adjustments..
Thx @zombi
Shadow WQHD Skin Update: 16.11.24 v3.0-r8
- My ShadowWQHD now includes the country flags, these were newly created by me and all of the same dimensions, as well as the missing one for Frisan, the system flags were created and installed very modestly, so I'm just providing them with the skin for now.
- The flags also look nicer in the vKeyboard
- The vKeyboard has received new icons, but the old ones are still included in the skin, because only with the new fixed and extended vKeyboard by Sven H will it work with the new, no longer fixed icons.
The flags and the new vKeyboard may also come as an update in the AIO when gutemine builds one again.
- This and that.
Update v3.0-r10 >>>>>(Online Update)..
New Update: 07.12.2024
- kleine Anpassung am PVR State..
- kleine Änderung bei einigen Screens..
- Rec Anzeige geändert..
- interne Skinbereinigungen..
Thx @zombi
