[BACKUP] Vu+ Zero 4K Open BlackHole 5.2.005
abou
Sponsor
Sponsor
Has thanked: 90 times
Been thanked: 92 times
Algeria
Post by abou »
[BACKUP] Vu+ Zero 4K Open BlackHole 5.2.005 by @Amos333 *** Open BlackHole 5.2.005 ***
>>>> Full BACKUP by @Amos333 <<<<
4. April 2023
Receiver: Vu+ Zero4K
Chipset: Broadcom 72604
CPU: ARMv7 1.5 Ghz Dual core
SoC: BCM72604
Memory: 4GB eMMC/2GB DDR4
LAN: 100 MBit/s
Video decoding: HVEC / H.265
------- Image specifications -----------
Image: Open BlackHole 5.2.005
Architecture: cortexa15hf-neon-vfpv4
Drivers: 07-04-2021
Kernel version: 4.1.20-1.9
Gstreamer , version 1.20.4-r0
Last update: 30-03-2023
Python version: 3.11.0
Start video resolution: 1920x1080p
Default language: English (US)
Network configuration: Automatic - DHCP
Tuner configuration: Positioner- USALS
Start motor position: Astra 19,2E
USALS coordinates: 20.5E - 44.8N (Belgrade, Serbia)
Channel list: @ciefp-E2-75E-34W-02.04.2023 motor & IPTV list
Start channel: IPTV Q Music (NL)
The Weather plugin location: Belgrade , Serbia
Skin: MX Maestra Blue FHD
------- Button Hotkey configuration ---------
Blue: CAM manager
Blue Long press: Extension menu
TXT: Raed Quick Signal Infobar
------- Telnet access ----------
Username: root
Password: amos333
-------- Installed plugins -----------
AJ Panel
DreamSat Panel
Multi-Stalker Portal
Jedi Maker Xtream
Jedi EPG Xtream
XCplugin
XStreamity
Filebrowser
Chromium OS
Dream-Explorer
E2i Player
CrossEPG Downloader
EPG Importer
EPGRefresh
FootOnSat
HasBahCa
IMDB & TMBD search
Internet Speed Test
Permanent Clock
Pluto TV
RAED Quick Signal
SubsSupport DVB Player
SubsSupport downloader
The Weather
YouTubeTV
Softcam tools:
Oscam & NCam Status
Free Server
Key Adder
Installed softcam:
NCam 13.5-r1 (patched by RAED)
SoftCam.Key, CCcam.cfg by @MOHAMED_OS
Keys stored in: /etc/tuxbox/config/
19,2E Astra SkyDE iCam StreamRelay = OK
NOTICE:
- Language selection & Video resolution setup is enabled on very first boot
- Startup channel is IPTV so you can set your USALS coordinates before you use motor list
(MENU -- Setup -- Tuners & Scanning -- Tuner Setup -- OK -- OK -- enter your coordinates -- OK -- EXIT)
- PermanentClock ON/OFF Menu -- Setup -- System -- PermanentClock -- Deactivate/Activate
Link to photo gallery:
Image ************************************ https://postimg.cc/gallery/yVQrygW --------------------------- DOWNLOAD link 1 ************************************************* https://www.mediafire.com/file/mvldpkrb ... 3.zip/file
Return to “Backup's image”
