TikTok v28.9.3
TikTok v28.9.3
TikTok v28.9.3 (Unlocked)(InBuilt RegionChanger)(Mod)(Plugin v2.7.4)
Overview: TikTok is THE destination for mobile videos. On TikTok, short-form videos are exciting, spontaneous, and genuine. Whether you’re a sports fanatic, a pet enthusiast, or just looking for a laugh, there’s something for everyone on TikTok.
★ Mods-
- Removed inVideo Google & Other ads
- Made video, pictures and GIFs downloading without watermark to Movies/TikTok folder instead of DCIM/Camera
- Removed all restrictions on downloads, you can download any video
- Removed many other restrictions
- The application was cleaned as much as possible
- Maximum compression + ZipAlign
- Disabled unnecessary activities
- Removed restrictions on duets, stitching
- Rewind is now available in any video
- Battery drain optimization
- Removed regional restrictions
- Fixed Google authorization
- Fixed Facebook authorization
- Fixed Twitter authorization
- Fixed VK authorization
- Disabled autostart
- Enabled High Quality Audio
- Enabled High Quality Video
- Hidden root rights
- Disabled InAppBillingService
- Disabled all types of Analytics
- Disabled mandatory login
- Added author tag for the name of the downloaded file
- Added ability to download profile pictures
- Monet app icon for Android 13+
What's new in this update?
Region names can now be translated into your language using Crowdin
- Synchronized translations with Crowdin
★ Exclusively Modded By DMITRY Nechoporenko
★ Plugin For TikTok Features-
- Details for regions (Long press on Region option)
- Option for matching post's region with selected region. (Don't show post's that are not related to selected region)
- Option for hide ads from trending list in discover section
- Option for disable playing videos in loop behavior
- Option for hide live streams from timeline
- Option for hide post captions from everywhere
- Option for hide long posts (with custom length) from timeline
-Ability to change download directory
- Ability to make keyword blocklist for captions (Post's with specific words will not appear in timeline)
- Remove Video watermark & GIF watermark options
- Ability to bypass duet & stitch privacy settings
- Theme switcher for plugin
- Added new speeds in playback speed option. (1.25x, 1.5x, 2.25x, 2.5x)
- Option for downloading videos without sound (Mute videos will save with mute.mp4 prefix)
- Option for changing font style (Currently support 6 new font + default)
- Option for changing ui colors like main bottom background color
- Added ability to reset plugin settings (Menu > Reset)
- Tap app bar for navigating to top of the options list
- Long press on options to see more info
★ Changelog-
★ Exclusively Redeveloped Further By DMITRY Nechoporenko
★ Note1- Working in Banned Countries, Tested in India, Vpn is required if tiktok server is blocked from your isp dns.
★ Note2- If you face "Too Many Attempts" Error on login, Use Forgot Password Option.
Easily add a sound to your video.
This app has credit advertisements
https://uploadrar.com/n470cz59byhh
eddiehere34
Been thanked: 1 time
Albania
Re: TikTok v28.9.3
Post by eddiehere34 »
Thanks, This is new version of Tiktok?
Has thanked: 14324 times
Been thanked: 1623 times
Re: TikTok v28.9.3
Yes international version
