IPAUDIOPRO BY_ZIKO_V1.0_Py3
The ipaudiopro plugin contains four packages for different audio sources, and each package includes full bin audio and an AD SPORT PREMIUM package.
BEIN A
BEIN B
BEIN C
BEIN D
BEIN E
BEIN F
And not only that
IPAUDIOPRO plugin
Radio broadcast audios
ARRIADIA TNT
RADIO MARS A
RADIO MARS B
RADIO RMC_FR
RADIO DELTA FM
RADIO AJIAL
and RADIO BEIN
possibility of relying on your own audio within the PLAYLIST package
1/ TS DELAY voice synchronization and commentary controlled by CH+ and CH- buttons
2/ Press the green button (RESET AUDIO) to return to the original channel sound.
2/ The MENU button enables you to enter the two plugin settings, which are as follows:
A: TIMESHIFT DELAY for adjustment and synchronizers
B: SHOW IPAUDIOPRO IN MAIN MENU
C: SHOW PICON To enable the display of audio icons
D: To enable EPG display on audio
After downloading, the file must be sent to the tmp directory
With giving the following command via Telnet
opkg install --force-overwrite /tmp/*.ipk
For images based on python2, the IPAUDIOPRO_v1.0 plugins will be released next week
Thanks ZIKO
[Plugin] IPAudio Pro
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
- enigma2_plugin_extensions_ipaudiopro_1_0+git19+eb77ad3_r0_mips32el.ipk
- (713.92 KiB) Downloaded 161 times
- enigma2_plugin_extensions_ipaudiopro_1_0+git19+eb77ad3_r0_cortexa15hf.ipk
- (706.5 KiB) Downloaded 138 times
- ocean777
- Has thanked: 239 times
- Been thanked: 210 times
Re: [Plugin] IPAudio Pro
New update same version 1.1 Python3.12
ARM/MIPSEL
- Adding a web interface
- The ability to add multiple playlists
- Solving the issue of the player freezing in certain situations
- Detecting a JSON file if it is on HDD or USB
ARM/MIPSEL
- enigma2-plugin-extensions-ipaudiopro_1.1+git112+3933b300+3933b30b56-r0_cortexa15hf-neon-vfpv4.ipk
- (1006.27 KiB) Downloaded 100 times
- enigma2-plugin-extensions-ipaudiopro_1.1+git112+3933b300+3933b30b56-r0_mips32el.ipk
- (993.92 KiB) Downloaded 124 times
Installation IPaudioPro
wget -qO- --no-check-certificate "https://gitlab.com/MOHAMED_OS/dz_store/ ... line-setup" | bash
OR:
curl -LJso- "https://gitlab.com/MOHAMED_OS/dz_store/ ... line-setup" | bash
OR:
V 1.4
-Add Support PY 3.13
enigma2-plugin-extensions-ipaudiopro_1.4_mips32el.ipk
https://fastupload.io/6b8afeec982508cb
enigma2-plugin-extensions-ipaudiopro_1.4_cortexa15hf-neon-vfpv4.ipk
https://fastupload.io/649b9b1e9c64af06
enigma2-plugin-extensions-ipaudiopro_1.4_aarch64.ipk
https://fastupload.io/6915073ae6aba15b
- 2029 Views
- 1394 Views
- 1209 Views
- 3190 Views
Last post by gregor1213
- 906 Views
