EnigmaE1 Pc Tools
General discussions, images, information, tutorials, picons, skins, plugins, settings, software and tools for receivers
Bagira
Silver Member
Silver Member
Has thanked: 48 times
India
EnigmaE1 Pc Tools
Post by Bagira »
help mi send
Dreambox OptiFlasher E1v1.0.2
This tool send mi
OptiFlasher E1v1.0.2%0Aimege.zip
(310.25 KiB) Downloaded 178 times
Bagira
Silver Member
Silver Member
India
Re: EnigmaE1 Pc Tools
Post by Bagira »
Help
My dm 500s is dcc password crack
Has thanked: 14318 times
Been thanked: 1598 times
Which image you use ??
Bagira
Silver Member
Silver Member
India
Post by Bagira »
The Founder wrote: ↑10 Mar 2023, 16:30 Which image you use ??
Dm500s Gemini 4.2.0
Menu, setup password=6070
Bagira
Silver Member
Silver Member
India
Post by Bagira »
This method not work
Netwerk error
*menu
setup
blue panel
addons
download gemini server
plugins
Tuxcom
OK
YES
OK
EXIT ALL
menu
setup
blue panel
Plugins
TuxBox Commander
scroll down to var
OK
scroll down to etc
OK
down to passwd and press 4 (edit)
OK on first line
RED to clear line
enter root::0:0:root:/root:/bin/sh with remote buttons like an writing an SMS
OK
EXIT
save YES
EXIT
save YES
EXIT
EXIT
EXIT
then login with telnet
login root
no pass !*
Bagira wrote: ↑10 Mar 2023, 20:20 This method not work
Netwerk error
*menu
setup
blue panel
addons
plugins
Tuxcom
OK
YES
OK
EXIT ALL
menu
setup
blue panel
Plugins
TuxBox Commander
scroll down to var
OK
scroll down to etc
OK
OK on first line
RED to clear line
OK
EXIT
save YES
EXIT
save YES
EXIT
EXIT
EXIT
login root
no pass !*
Old image supports ended you can use latest image open pli with oscam
Bagira
Silver Member
Silver Member
India
Post by Bagira »
Bagira wrote: ↑09 Mar 2023, 14:43 help mi send
This tool send mi
A tools mil jaye to mera kam ho jaye ga
https://youtu.be/5TPgqBsfEc0
Bagira
Silver Member
Silver Member
India
Post by Bagira »
Bagira wrote: ↑10 Mar 2023, 15:34 Help
I dont understand this
Tuxbox commander is password protected
Hi everyone
If you find that access to tuxbox commander is password protected, this is the method for you.
When run, the attached plug-in, it will change the password to 'DreamBox'. When run again the password is set back to whatever it was before the first run.
Obviously if you do not have root access you will not be able to FTP this plugin to dream box. All around this, is to mount a shared folder to the dream box on your PC, then install a manual plugin on the DreamBox, browse to the mountand pick it up from there.
It has only been tested on the DM 500 with Gemini 4.20.
If you break something while logging in as root, it's your own fault!
What does it do? It just replaces the passwd file with one where 'DreamBox' is the root password and stores the original elsewhere. If you run it a second time it swaps back the old file, setting the password back to one you don't know. Thus set up a network mount for your folder with the plugin.
On your PC:
1: Create a folder somewhere on the PC. (Do not use any space in the name)
2: right click on folder -> select properties -> select Sharing tab - > tick 'share this folder on network' and if you want to write to it, tick "allow network users to change my files".
3: Click 'Apply'
On DreamBox:
1: Go to blue panel - > extras / setup - > automount
2: press the yellow button to add a new share.
3: leave the mount point as 'NFS'.
4: Change the client IP to your PC.
5: Select 'CIFS' in the dropdown menu
6: Enter the name of the folder you created earlier in the' client dir'.
7: Enter your PC username and password in the slot provided.
8: press the green button to save.
You may have to press the green button a second time in the auto Mount main menu 'restart'.
The mounted folder will appear under /automount/NFS. It will not appear in the Plugins menu, but you can browse the file and execute it with tux commander.
We only need password switcher .
Return to “Dreambox”
