[Skin] MetrixFHD
admin
SF FOUNDER
SF FOUNDER
Has thanked: 1662 times
Been thanked: 422 times
[Skin] MetrixFHD
Post by admin »
New Metrixfhd-neo V.2
10/05/2022
-Added several options
Thanks neo3
W@Rp
Has thanked: 3 times
Been thanked: 34 times
Greece
Re: [Skin] MetrixFHD
Post by W@Rp »
Metrixfhd-neo_oatv7s v6 Upgrade 22/01/2024
enigma2-plugin-skins-metrixfhd-neo_V.7s_v6_all.rar
(846.64 KiB) Downloaded 77 times
Has thanked: 14360 times
New Metrixfhd-neo _oatv-7s__restart
19/03/2024 Restart Upgrade
The Skin is for Series 7 only
changes to version 6:
I removed the xtraevent plugin from the skin installation
The plugin can be installed separately via telnet
The skin has panels with covers etc. in the Metrixfhd-neo configuration menu options. in full
therefore, anyone who wants to use these features is obliged to install the plugin.
I inserted in the zip file together with the skin, the text file with the code to install the extraevent plugin
If something in the plugin doesn't work [don't ask me] the skin works perfectly
I redid some panels for the various image updates of the last 5 months
I have inserted some panels created by [ncc1701] into the allScreens (Thanks)
and other things I don't remember.
Play around with it and you'll see the differences.
script xtraevent telnet.rar
(187 Bytes) Downloaded 71 times
