SFVIP-Player-x64 / SFVIP-Player-x86
SFVip Player The best Player for IPTV on Windows
SFVip Player is one of the best IPTV player for Windows, where you can add m3u playlists and lists, and also access Xtream Codes API, even use as an STB Emulator for Windows.
As it is in a .zip file, we will have to unzip it in a folder on your PC, we will have several files, the most important is sfvip player.exe which we execute.
We can manage and add multiple IPTV accounts, to add one we have to click on the button above <…> and then on the button ➕👤, and then a menu will appear where we can choose the following options:
MAC: in this section it will act as an STB emulator where you can enter a MAG account. The important data is the Portal Address or URL, and the MAC that you have to generate manually.
User/Pass: in this section add an Xtream Codes API account, the important data is the URL or Address, Username and Password provided by the IPTV provider.
And you have several options like:
TV Recorder / Take Photo
Show Subtitles and Change Audio
Mini Player and Full Screen
Player video over all windows
Color, brightness and contrast adjustment
integrated EPG
To download the latest version of SFVip Player go to these links:
For 32bits: https://uploadrar.com/1lore2h74k0m
For 64bit: https://uploadrar.com/qb97iak5zodx
Fer
Has thanked: 1 time
Been thanked: 3 times
France
Re: SFVIP-Player-x64 / SFVIP-Player-x86
Post by Fer »
merci
mohamedrezk
Been thanked: 1 time
Egypt
Post by mohamedrezk »
thank you sfvip player great
hurmaz
Post by hurmaz »
many thanx..................
amontexas
France
Post by amontexas »
hello I have a problem every time I put a mac or mu3 and loading the channel the software closes
eclair
Has thanked: 38 times
Been thanked: 10 times
Algeria
Post by eclair »
Je confirme l'un des meilleurs players pour Windows que ce soit pour les chaines,les vod ou séries et même pour la conversion de mac en m3u
Merci pour le partage
a974
Russia
Post by a974 »
Good evening. Tell me please. I downloaded a playlist with channels divided into groups (sports, news, etc.), but for some reason the program does not show channel groups, but shows all channels. How can I fix this?
p060477
Has thanked: 3 times
Been thanked: 2 times
Belarus
Post by p060477 »
where is salezli player...??...
its github disappeared:
https://github.com/K4L4Uz/SFVIP-Player
there is only an old page on webarchive:
https://web.archive.org/web/20250302164 ... VIP-Player
where is K4L4Uz...??...how to have its salezli sfvip player updated?
thxs in adv cheers
p060477
Belarus
Post by p060477 »
no news about salezsly player...??
Has thanked: 14363 times
Been thanked: 1661 times
