[Plugin] Movietime
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
[Plugin] Movietime
A new enigma2 plugin Movietime - is attached below. It should work with both Python 2 and Python 3 images.
With some python 2 images - to play videos please use Download -> Current downloads -> select item -> Play.
thanks pcd.
thanks pcd.
- enigma2-plugin-extensions-movietime_1.0_r1_all.ipk
- (3.39 MiB) Downloaded 91 times
- enigma2-plugin-extensions-movietime_1.0-r1.0_all.deb
- (2.87 MiB) Downloaded 64 times
- sugar
Re: [Plugin] Movietime
MTupdate
It should remove the skins name error, add the video name to the play or downloaded items, and improve the python 3 download method.
thanks pcd
thanks pcd
- MTupdate1.zip
- (174.48 KiB) Downloaded 87 times
- sugar
20221106
New version of addon plugin.video.filmxy
Please first remove the existing addon (Movietime first screen - Red button) and next install the new version (Movietime first screen - Green button).
- plugin.video.filmxy-1.0.5.zip
- (104.56 KiB) Downloaded 81 times
- sugar
20221218
The following movies addon is attached below. It has been tested with a python 3 image, but it may also be ok with some python 2 image. Please put the zip files in /tmp folder and install via Movietime first screen - green button.
plugin.video.asgard-1.5.0
It requires the following script module which is also attached below.
script.module.resolveurl-5.1.85
- plugin.video.asgard-1.5.0.zip
- (3.51 MiB) Downloaded 75 times
- script.module.resolveurl-5.1.85.zip
- (1.68 MiB) Downloaded 77 times
- sugar
20230203
The following updated iptv addon is attached below. It has been tested with a python 3 image (openatv 7.1), but it may also be ok with some python 2 image.
plugin.video.HasBahCa-1.0.4
thanks pcd
thanks pcd
- plugin.video.HasBahCa-1.0.4.zip
- (1.17 MiB) Downloaded 54 times
- sugar
20230204
The following updated addon is attached below. It has been tested with a python 3 image (openatv 7.1), but it may also be ok with some python 2 image.
plugin.video.dailymotion-2.4.4m
thanks pcd
thanks pcd
- plugin.video.dailymotion-2.4.4m.zip
- (311.37 KiB) Downloaded 81 times
- sugar
20230214
plugin.video.iplayerwww-4.0.3
It requires the following script - which is also attached :-
script.module.inputstream.adaptive-2.6.16
- script.module.inputstream.adaptive-2.6.16.zip
- (790.48 KiB) Downloaded 86 times
- plugin.video.iplayerwww-4.0.3.zip
- (412.88 KiB) Downloaded 85 times
