Backup image Egami 10.3r9 for Novaler Multibox/SE
abou
Sponsor
Sponsor
Has thanked: 90 times
Been thanked: 92 times
Algeria
Post by abou »
Backup for the excellent image Egami 10.3r9 with the latest version and the latest additions from "Takichy" for Novar devices in two versions:
Novaler Multibox/SE
Novaler Multibox/SE
Telnet / FTP picture connection data:
user = root / password = root
As for extras, as always:
Oscam and Ncam support all features (icam / download free servers / get encryption keys from the Internet and read CCcam.cfg)
I added you a copy of the free servers directly as soon as you run the emo
and configuration files in the path:
etc/tuxbox/config
Note that the Backup is equipped with what makes it run the servers of the device (SupTV and NovaCam)
Blueaccent FHD Giant Knife has been added
With regard to the channels, I have added something special for you, which is the ability to choose the channels according to your desires by pressing the "RADIO" button, then choosing the file you want according to the satellites it contains.
SKY channels It works perfectly in various ways, and has been modified to work perfectly using dual emoticons (SupCam_NovaCam, SupCam_Oscam, or SupCam_NcamFreeServer)
قنوات البث الأرضي الاسبانية على القمر 30w شغالة - القنوات الروسية على القمر 14w شغالة .
الدليل الالكتروني للقنوات المهمة دون الحاجة لبلجن Grabber
كما تمت إضافة خاصية HbbTV على الصورة 🥰
الجهاز Novaler Multibox 4K (الإصدار الأول) : https://www.mediafire.com/file/2wwfhbwd ... 3.zip/file Novaler Multibox 4K SE (second edition): https://www.mediafire.com/file/j3f63k8q ... 3.zip/file In the end, I hope that this work will meet your satisfaction and aspirations. good luck for everbody - Greetings, your brother Taqi Al-Din - Takichi.
Malik3431
Has thanked: 77 times
Been thanked: 107 times
Re: Backup image Egami 10.3r9 for Novaler Multibox/SE
Post by Malik3431 »
can i install this images on star sat 2020hd+ ?
ZGEmMA H7sSR-90000 eXtreme
Has thanked: 14324 times
Been thanked: 1607 times
Malik3431 wrote: ↑26 Jan 2023, 23:47 can i install this images on star sat 2020hd+ ?
Never try because this is android machines update
Return to “Others STB”
