BoxPirates Panel
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
BoxPirates Panel
BoxPirates Panel
V1.9
-Plugin completely revised
-Completely new look (Skin)
-Oscam for the Drambox One added
-Configs completely revised (only load and start)
-Current gbox added
V1.9
-Current gbox added
- sugar
Re: BoxPirates Panel
BoxPirates Panel
V1.9_r6
● Fix, delete the panel if the good feed was also installed
● Associated with this is a relaunch of the panel as Boxpirates CamManager
Attention:
Before installing version 1.9.0-r6 for DreamOS, please try to uninstall the old version.
This applies especially to users who have already deleted the panel
V1.9_r6
Attention:
apt-get remove --purge enigma2-plugin-extensions-boxpirates-panelSupport Our Mission! Donate For Forum
- sugar
oxPirates-CamManager_1.9.2-r0
- Feed check optimization
- Feed added for future use
wget http://plugins.boxpirates.dynvpn.de/boxpiratespanel-ipk-installer.sh -O - | /bin/shCode: Select all
wget http://plugins.boxpirates.dynvpn.de/boxpiratespanel-dreamos-installer.sh -O - | /bin/sh- Attachments
- enigma2-plugin-extensions-boxpirates-cammanager_1.9.2-r0_all.ipk
- (1 MiB) Downloaded 102 times
- sugar
pdate to version 1.9.3-r0 (OE2.0)
- Fix Crash at "OK" if no Cam/Emu is selected
- Fix Link/Right for OpenATV 7.2
- Optimisation start/restart handling
- Old feed URLs removed
Update to version 1.9.3-r0 (>= OE2.2)
- Old Feed-URL's removed
Installation via console (OE1.6 / OE2.0) [.ipk]
Installation via console (DreamOS) [.deb]
wget http://plugins.boxpirates.to/boxpiratespanel-ipk-installer.sh -O - | /bin/shInstallation via console (DreamOS) [.deb]
wget http://plugins.boxpirates.to/boxpiratespanel-dreamos-installer.sh -O - | /bin/shSupport Our Mission! Donate For Forum
- sugar
Update to version 1.9.4-r0 (>= OE2.2)
- WQHD (2560x1440) skin added (Universal Image)
- Fix crash on "OK" if no cam/emu is selected
- sugar
Update to version 1.9.5-r0 (>= OE2.2) and (OE2.0)
- Translation added
- Translation added
