Mutant HD51 (OPEN VIX IMAGE)
lider
Been thanked: 994 times
Post by lider »
Technical Specification:
Mut@nt HD51 HEVC-4K UHD
Processor
Broadcom BCM7251S CPU
ARM Cortex A15
Dual Core 1700Mhz (21.7GHz)
12K DMIPS CPU
SoC 28nm
Video/Audio Output
HDMI 2.0 (SDR/HDR)
RCA CVBS Video with L/R Audio
SPDIF Optical Audio
Configuration
2xPnP DVB Tuner Slot
eMMC Nand Flash 4GB
SPI Flash 8MB
DDR Memory 1GB
OpenGL ES 2.0
VFD 16-Digit Dot Matrix Display
1xCI Common Interface
1xSmartcard Reader
Connectivity
RJ45 Gigabit Network LAN (1Gbit)
USB 3.0-a SuperSpeed Rear (4.8Gbit)
2xUSB 2.0 HighSpeed Front/Rear (480Mbit)
SATA3 2.5” Internal Drive Bay (6Gbit) or External (Optional)
Tuners
2xInterchangeable Plug and Play DVB Tuner
Included tuners: 2xSatellite
Available options:
-DVB/S2
-DVB/S2/S2x
-DVB/C/T/T2
– 4x USB vtuner
Tuner bei SW:
– Fall back Tuner
– SAT>IP
Video/Audio decoder
HEVC H.265 4Kx2K/60P
Max Video Resolution 2160p (4K/UHD)
OpenGLES 2.0
H.263, H.264, H.265, MPEG-1, MPEG-2, VC-1, AVS+, DivX, VP6, VP8, VP9, XVID
AAC, AC3, DDP, FLAC, LPCM, MPEG, Ogg Vorbis, SRS, PCM on WAV, Real Audio, WMA, DTS
VP8 Youtube - Yes
VP9 4K Youtube (coming soon)
Physical/Power Characteristics
Dimensions (WxHxD): 30 x 22 x 5cm
Supply External 12V
Consumption (FSD): 13.1W / 7.1W / 0.5W Standby
https://www.openvix.co.uk/openvix-build ... _multi.zip
https://www.openvix.co.uk/openvix-build ... y_emmc.zip
Return to “Others STB”
Users browsing this forum: Dot [Bot] and 1 guest
