Emby Dream
It's never been easier to gather all your home videos, music and photos in one place.
Your personal Emby server will automatically convert and stream your media to play on any device.
To be able to use the plugin, an Emby server or Jellyfin server must be available.
EmbyDream Client Plugin for 7080, 9xx, One and Two supports movies, series and music content.
wget http://plugins.boxpirates.to/embydream- ... staller.sh -O - | /bin/sh
Update online
Version 1.2.1
- add user fix
[Plugin] EmbyDream DreamOS-DEB
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
Re: [Plugin] EmbyDream DreamOS-DEB
Update online
Version 1.2.3
- strm file is supported as playback source
- List view revised
- Cover view revised
- Emby Trailer plugin is supported
- Photo viewer added
- Emby queries revised
- Skins revised
- 2560x1440 skin is supported (Universal Image DreamOS)
- adapted for the new DreamOS Universal Image
- new filter list created
- added several languages (most of it now comes from Emby herself)
- Background images can be activated in the cover and list view (then gets a bit sluggish when zapping)
- various minor bugs fixed
- Texts that are too long will be cut off and marked with "..." finished
- Playlist music video fix
thanks murxer
Version 1.2.3
- List view revised
- Skins revised
thanks murxer
- kingsman
- Has thanked: 13 times
- Been thanked: 268 times
Version 1.2.7
- Screen update fix
- Play next episode fix (if no ParentID is present)
- Fixed wallpapers
- Theme Player reworked
- Background videos or music can be ended with the stop button
- LiveTV channel "Play" fix
- LiveTV Player Fb Assignment
Update online
thanks murxer
- Screen update fix
- Fixed wallpapers
Update online
thanks murxer
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
Version 1.3.8
- Api Abfragen überarbeitet
- Error-Log an und abwählbar (default deaktiviert) -> findet ihr in den Einstellungen
- Serien Info erweitert
- Serien Info Ende oder Aktuell hinzugefügt
- Trailer fix
- 'UnplayedItemCount' Crash fix
thanks murxer
OpenPLI Image:
enigma2-plugin-extensions-embydream_1.3.8_mips32el.ipk
https://www.boxpirates.to/index.php?att ... s32el-ipk/
enigma2-plugin-extensions-embydream_1.3.8_cortexa15hf-neon-vfpv4.ipk
https://www.boxpirates.to/index.php?att ... vfpv4-ipk/
enigma2-plugin-extensions-embydream_1.3.8_armv7vehf-neon-vfpv4.ipk
enigma2-plugin-extensions-embydream_1.3.8_armv7ahf-neon.ipk
https://www.boxpirates.to/index.php?att ... -neon-ipk/
VTI Image:
enigma2-plugin-extensions-embydream_1.3.8_armv7ahf-vfp-neon.ipk
Images mit Python 2.7:
Images mit Python 3.11.2: z.b OpenATV 7.3, NRF 7.3. OpenHDF 7.3 ...
enigma2-plugin-extensions-embydream_1.3.8+git51+f5cae44-r73_mips32el.ipk
enigma2-plugin-extensions-embydream_1.3.8+git51+f5cae44-r73_cortexa15hf-neon-vfpv4.ipk
https://www.boxpirates.to/index.php?att ... -neon-vfp/
enigma2-plugin-extensions-embydream_1.3.8+git51+f5cae44-r73_cortexa7hf-vfp.ipk
https://www.boxpirates.to/index.php?att ... f-vfp-ipk/
Images mit Python 3.12: z.b OpenATV 7.4, NRF 7.4. OpenHDF 7.4 ...
enigma2-plugin-extensions-embydream_1.3.8+git51+f5cae440+f5cae4434f-r74_mips32el.ipk
https://www.boxpirates.to/index.php?att ... -mips32el/
enigma2-plugin-extensions-embydream_1.3.8+git51+f5cae440+f5cae4434f-r74_cortexa15hf-neon-vfpv4.ipk
https://www.boxpirates.to/index.php?att ... -cortexa1/
enigma2-plugin-extensions-embydream_1.3.8+git51+f5cae440+f5cae4434f-r74_cortexa7hf-vfp.ipk
https://www.boxpirates.to/index.php?att ... -cortexa7/
- Trailer fix
thanks murxer
OpenPLI Image:
VTI Image:
- 3653 Views
Last post by gregor1213
- 1110 Views
- 857 Views
- 679 Views
- 768 Views
