Amazon Prime Enigma2 Plugin
lider
Been thanked: 994 times
Post by lider »
wget http://amazonprimedream.boxpirates.dynv ... staller.sh -O - | /bin/sh
version 1.4.2
-Amazon Prime is supported for different countries. To do this, select the corresponding Amazon URL in the settings. The films are then loaded and played accordingly for the country.
Currently supported countries:
amazon.co.uk
amazon.de
amazon.es
amazon.fr
amazon.it
amazon.pl
amazon.se
Note: Amazon blocks access from certain countries depending on location. If there is a problem, the plugin reports an Amazon API error.
Note: The cookies are now stored in a new file "/var/lib/widevine/amazonprimedream.cookie". The login is automatically taken from the old file. In the future, therefore, new logins in the VOD plugin will no longer have any effect on this plugin.
- BUGFIX: If a series has been watched to the end, the resume time is now set correctly again.
- BUGFIX: Jumping to the next episode for series works again.
- BUGFIX: Starting the next episode after completing the current episode works again for series.
- BUGFIX: Visibility of subtitles is checked correctly (previously led to error messages in the log)
