InfoBarWeather
a new plugin that shows the weather in the infobar:
•Location
•Last update time
•Sunrise
•Sunset
•Humidity
•2 hour rain forecast (The Netherlands & Belgium only)
•Wind direction and speed
•Temperature
•Apparent (feel) temperature
It has built-in support for PLi-FullNightHD and PLi-FullHD skins.
Update: v.0.10
-Widened the Screen a bit so it plays nicer with Louis skin.
Thanks @ scriptmelvin
[Plugin] InfoBarWeather
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
- enigma2-plugin-extensions-infobarweather_all.ipk
- (43.86 KiB) Downloaded 113 times
- sugar
Re: [Plugin] InfoBarWeather
Update: v.0.11
Add French translation (thanks @ Pr2)
Small layout changes
Fix wrong feel temperature color
Fix change settings has no effect
Fix change settings forgets location
- enigma2-plugin-extensions-infobarweather_all(1).ipk
- (30.89 KiB) Downloaded 109 times
- sugar
v.0.15
Update
Add Russian translation
Update
- (32.96 KiB) Downloaded 89 times
- sugar
v.0.17
-Add US units (mph and °F)
-Add Albanian translation
- (34.87 KiB) Downloaded 132 times
- 3653 Views
Last post by gregor1213
- 1110 Views
- 857 Views
- 679 Views
- 768 Views
