SKIN Novaler-S-FHD-Blue v3.2
Has thanked: 14329 times
Been thanked: 1640 times
👆The new version of the Novalir S
Novaler-S-FHD-IndianRed v3.2
New in this release:
1 - Completely modifying the background screens to appear in a plain dark color instead of the wooden black.
2- Experiment with the red color.
3 - Adding new screenshots of the Egami image for more compatibility with the Igami images.
4 - Adding the channel's reference and the definitions of sound and image in the second infobar.
5- More code fixes.
6- Reducing the size of the skin to 7.8 megabytes.
Skin compatible images:
Openpli 8.1
Openatv 6.4
Openatv 7.0
Openatv 7.1
Egami 9.0.4
Egami 10.0
Egami 10.1
Openspa 7.5
Pure2 6.5
OpenHDF 6.5
OpenHDF 7.0
OpenBH 5
Satlodge 8.1
Satlodge 8.2
Pkteam hyperion 8
Nonsolosat
Openvision 11.2
Version X depends on the enhanced renderer posterx to bring posters
The Xtra version depends on the xtraevent plugin to fetch the posters, and the settings must be set in a good way
Therefore, version X is the easiest and best for beginners.
Skin files in IPK format
Installation method:
*Using ajpanel plugin
The file is selected and the installation command is force overwrite
* Using the following telnet command, provided that the file is transferred to the tmp folder
opkg install --force-overwrite /tmp/*ipk
X version link
https://www.mediafire.com/download/cw44tp51rbvfodx
Xtra version link
https://www.mediafire.com/download/wbwn4vv6s8ileyj
