DemonEditor Version Beta macOS 🧿⭐✅🔥
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
Demon Editor V1.0.10 Beta released.
- Added menu item "Save as".
- Added recordings tab to the control panel.
- Data deletion optimization.
- Minor optimization of favorites list loading.
- Minor filtering optimization.
- Added Chinese translation" thanks to roc"
- DemonEditor-1.0.10-b1
https://sbupload.com/ba27b49ad1f1881a
- DemonEditor-1.0.10-Beta.deb
https://sbupload.com/554d7279f1a1030d
- sugar
Re: [*.DM] E2 DemonEditor Version Beta macOS [*.dep] 🧿⭐✅🔥
Demon Editor ..
- version 2.0.1 beta
- Fixed path to picons on profile change.
- Fixed themes unpacking for Windows.
- Fixed getting youtube-dl for Windows.
- Enabled HTTP API setting for Neutrino.
- Polish translation update (thanks to wwns).Turkish translation update
Windows bundles [64-bit] was created using the MSYS2 Building Platform.
This version uses MPV to play streams. All required libraries are already included in the package.
Builds for MS Windows are experimental and not fully tested!
- DemonEditor-2.0.1-Beta-win64-MPV.
https://github.com/DYefremov/DemonEdito ... 64-MPV.zip
https://github.com/DYefremov/DemonEdito ... -win64.zip
- DemonEditor-2.0.1-Beta.deb
https://github.com/DYefremov/DemonEdito ... 1-Beta.deb
- sugar
Demon Editor ..
- version 2.0.3 beta
- Improved picons filtering and assignment (#49).
- Support for marking and filtering of services not presented in bouquets.
- Support for sub-bouquets creation (experimental, not fully tested).
- State saving for the main panels.
- https://github.com/DYefremov/DemonEdito ... 64-MPV.zip
- https://github.com/DYefremov/DemonEdito ... -win64.zip
- https://github.com/DYefremov/DemonEdito ... 3-Beta.deb
- https://github.com/DYefremov/DemonEdito ... Editor.dmg
- sugar
Demon Editor ..
- Version 2.1.0 Alpha released.
- Basic alternate layout support.
Tooltips support for the bouquets list.
- Improved bouquet export to *.m3u .
- Data rendering optimizations.
- Minor rework of picon assignment.
- Minor rework of recordings tab.
- Minor rework of FTP client.
- Basic editing support for FTP client (Not fully tested.).
- Multi-stream transponders support for LyngSat (Not tested).
- Multi-stream support for services web import (Not tested).
- Minor revision of satellite update dialog.
- Reduced waiting time for web import.
- Corrected satellite update from KingOfSat.
- Fixed satellites web update from FlySat.
- Fixed missing default ID for IPTV dialog.
- Alternate Gay layout is enabled by default for macOS build! Can be disabled in the "View" menu.
The library sets for all packages have been updated. Builds for MS Windows are not fully tested!
- https://github.com/DYefremov/DemonEdito ... -Alpha.deb
- sugar
Demon Editor ..
- Demon Editor version 2.1.0 Beta
- Added info panel auto closing for playback.
- Minor revision and improvement of the EPG dialog functionality (#59).
- Reworked built-in function for getting YouTube links.
- Updated Russian, Belarusian and German translations.
https://github.com/DYefremov/DemonEdito ... 0-Beta.deb
- sugar
Demon Editor ..
- Demon Editor version 2.1.2 Beta
- Improved MPV support.
- Fixed individual bouquets selection for import on macOS (#63).
- Fixed reordering bouquets using drag and drop on macOS and Windows (#64).
- Fixed current channel recording on Windows.
Builds for MS Windows have not been fully tested
https://github.com/DYefremov/DemonEdito ... 2-Beta.deb
- sugar
Demon Editor....
- Version 2.2.1 Beta released.
-Tooltips support for the main IPTV list.
-T2-MI PLP ID support for satellites.
-Playback support from the main list (experimental).
-Minor rework of the settings dialog.
-FTP bookmark activation via single click.
-Italian translation update (thanks to Massimo Pissarello).
-Fixed IPTV streams checking on Windows.
-Fixed incorrect data saving on Windows.
- sugar
Demon Editor....
- V 2.2.2 Beta released.
- Filtering support for the recordings tab.
- Minor changes in the settings dialog.
- Minor style changes for macOS.
- Fixed some names parsing for the KingOfSat source.
- Fixed translation missing for some elements on Windows
- Italian translation correction (thanks to Massimo Pissarello).
- Improved installer for Windows (thanks to Massimo Pissarello).
https://github.com/DYefremov/DemonEdito ... nstall.exe
- sugar
Version 3.3.0 Beta released
Additional time columns for the EPG tab
References assignment from filtered list only
"Replace existing" option for import dialog
Unlimited copy buffer option for bouquets tab.
Time display correction for XMLTV source.
Clearing EPG on profile change.
Fixed EPG update for alternative services.
Some GUI changes and corrections.
Updated Italian translation (thanks to Massimo Pissarello).
DemonEditor/releases/tag/3.3.0-b1
https://github.com/DYefremov/DemonEdito ... g/3.3.0-b1
