How to install oscam and cccam in enigma2?
General discussions, channel lists, images, information, tutorials, picons, plugins, settings, skins, software and tools for Vu+ receivers
Najeeb khan
Sponsor
Sponsor
Has thanked: 178 times
Been thanked: 286 times
Post by Najeeb khan »
brother shahid Geo me ne pehle bhi aap ko msg kia tha me Ncam use kar raha hn me 40 bar download kia he oscam & cccam lekin instal ni hoti aap kuch time nikal kar step by step batao takeh mujhe kuch samajh aa jae thanks
Brother i aks you many times tell me how to install oscam and cccam plzz share method step by step
Thanks members ❤️
Has thanked: 14360 times
Re: oscam and cccam
piplan1966 wrote: ↑05 May 2022, 12:08 brother shahid Geo me ne pehle bhi aap ko msg kia tha me Ncam use kar raha hn me 40 bar download kia he oscam & cccam lekin instal ni hoti aap kuch time nikal kar step by step batao takeh mujhe kuch samajh aa jae thanks
Brother its very easy install oscam or cccam
1st download oscam file 2 Put in USB or dcc use send file to temp folder
3 menu go to setup there select Software management here select install Local extantion after there show 3 options
Harddisk ( hdd)
Internal flash (box memory)
Momory /temp
There show ipk file press ok and install
4 oscam configuration
Open dcc go to etc/tuxbox/Config/oscam.server edit add your line and save restart oscam enjoy
:tfds
Regarding
Administration Staff
admin
SF FOUNDER
SF FOUNDER
Has thanked: 1662 times
Been thanked: 422 times
Re: How to install oscam and cccam in enigma2?
Post by admin »
How to install OSCam on an Enigma 2 box
In this easy tutorial, you`ll learn how to install OSCam softcam on an Enigma 2 box manually.
Below are the requirements:
1-Installation package file compatible to your box. You can download the proper file here.
2-Knowledge of working with SSH and STFP protocols. If you need help, read this tutorial.
3-A FTP client with which you'll transfer the installation package file inside your box
Transferring the file into the box:
1-Login onto your box via the FTP software using the SSH credentials of your box
2-From the left side, browse /temp/ folder
3-From the left side which is your computer, drag-and-drop the installation package file to the left side inside /temp/ folder
Installing OSCam:
1-Click the Blue button while the screen is empty
2-Go down to Plugins and hit OK
3-Select IPK Installer and click OK
4-Choose Memory /temp
5-Go to Install Extensions and hit OK
6-Press the Green button to install the Installation Package file
Putting OSCam Config Files inside the box:
1-Connect to the box using that FTP software again
2-From left side, browse /usr/keys/ folder and place oscam.server and oscam.conf there
Note: If you do not know how to make OSCam config files, let us know.
Activation of OSCam through softcam panel:
1-Press the Blue button
2-Choose Softcam
3-Choose Softcam Panel and press OK
4-Choose OSCam and press OK
5-Once countdown is done, OSCam starts working.
Najeeb khan
Sponsor
Sponsor
brother aap ki oscam tmp me drag ki he us ko seleckt kar ke install wala batton press karta hn to led ka rang kala ho jata he kuch bhi show ni hota ek mint tak remot ka koe batton kam ni karta ek mint ke baad ok karta hn to tmp me aap ki file samne aati he me ne soft cam se jo instal ki he wo bhi aap ko dikhata hn
Najeeb khan
Sponsor
Sponsor
click on file
Najeeb khan
Sponsor
Sponsor
click on oscam server
admin
SF FOUNDER
SF FOUNDER
Post by admin »
Ok good you have to success 😉
Najeeb khan
Sponsor
Sponsor
brother jab line add karta hn to oscam ok ni hoti
admin
SF FOUNDER
SF FOUNDER
Post by admin »
piplan1966 wrote: ↑05 May 2022, 18:51 brother jab line add karta hn to oscam ok ni hoti
How to add line past here configuration of cccam
dadsdf
Has thanked: 66 times
Been thanked: 9 times
Croatia
Post by dadsdf »
Eline sağlık
Return to “Vu+”
