The LATEST OSCAM-EMU FOR VARIOUS PLATFORMS
Been thanked: 1668 times
Update.. @ MOHAMED_OS
- OSCam 11715 ICam V9
Add Patch V9 for iCam's
- Adjustment for CMake
- Compiler parameter -fno-schedule-insns added. (Thanks @@Hacker1 )
- Removed compiler parameter -fno-tree-vectorize. The binary runs about 10% faster with neon (thanks @@eldi0s )
- Small change in ffdesca, which is slightly faster.
oscam-svn11715-mips-emu-r798.zip
(1.02 MiB) Downloaded 312 times
oscam-svn11715-arm-emu-r798.zip
(902.47 KiB) Downloaded 362 times
oscam-svn11715-aarch64-emu-r798.zip
(1001.92 KiB) Downloaded 241 times
Re: The LATEST OSCAM-EMU FOR VARIOUS PLATFORMS
OSCam-Patched-Icone-3361-798-(Sisyphe)-2022.12.25
https://www.mediafire.com/file/u33ngk0drku4jmv/OSCam-Patched-Icone-3361-798-(Sisyphe)-2022.12.25+2.zip/file
@ samur
OSCam-11732-799
OSCam-11732-799 (aarch64 libusb pcsc).zip
(755.92 KiB) Downloaded 199 times
OSCam-11732-799 (aarch64 libusb).zip
(753.45 KiB) Downloaded 228 times
OSCam-11732-799 (mipsel libusb aio).zip
(710.63 KiB) Downloaded 189 times
OSCam-11732-799 (mipsel libusb pcsc).zip
(662.67 KiB) Downloaded 182 times
OSCam-11732-799 (mipsel libusb).zip
(660.93 KiB) Downloaded 225 times
OSCam-11748-800 mipsel
OSCam-11748-800 aarch64
List of STB's:
Dreambox ONE
Dreambox TWO
CoreELEC
Rpi 3
Rpi 4
thx samur
OSCam-11748-800 (mipsel libusb).zip
(649.64 KiB) Downloaded 201 times
OSCam-11748-800 (mipsel libusb pcsc).zip
(651.98 KiB) Downloaded 201 times
OSCam-11748-800 (aarch64 libusb).zip
(684.31 KiB) Downloaded 211 times
OSCam-11748-800 (aarch64 libusb pcsc).zip
(686.31 KiB) Downloaded 217 times
Changeset [11757] by bust3d
- git-svn-diff.sh changed permission to 755 (thanks to WXbet) - fix …
oscam-svn11757-dreambox_fpu-webif-dvbapi-ssl-libusb-libdvbcsa-icam-mixed.rar
(698.83 KiB) Downloaded 200 times
oscam-svn11757-dreambox_fpu-webif-dvbapi-ssl-libusb-libdvbcsa-emu801-icam-mixed.rar
(742.7 KiB) Downloaded 163 times
oscam-svn11757-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-icam-mixed.rar
(693.56 KiB) Downloaded 206 times
oscam-svn11757-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu801-icam-neon-mixed.rar
(736.01 KiB) Downloaded 161 times
oscam-svn11757-dream_arm-webif-dvbapi-ssl-libusb-libdvbcsa-emu801-icam-mixed.rar
(733.8 KiB) Downloaded 216 times
oscam-svn11757-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-icam-neon-mixed.rar
(727.72 KiB) Downloaded 152 times
oscam-svn11757-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-icam-mixed.rar
(727.7 KiB) Downloaded 183 times
oscam-svn11757-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu801-icam-neon-mixed.rar
(771.29 KiB) Downloaded 182 times
oscam-svn11757-dream_aarch64-webif-dvbapi-ssl-libusb-libdvbcsa-emu801-icam-mixed.rar
(771.28 KiB) Downloaded 188 times
Changeset 11758 with EMU 801
simplify cak7 code (thanks to lpm11 and for all who tested)
What is new in EMU 801
-[powervu] Add emm unmask mode 4
build juli13
oscam-11758-mipsel-EMU.zip
(1.16 MiB) Downloaded 183 times
oscam-11758-arm-EMU.zip
(956.08 KiB) Downloaded 183 times
oscam-11758-aarch64-EMU.zip
(1007.33 KiB) Downloaded 177 times
Changeset OsCam 11766
New Update 18.04.2024
Changeset [11766]
-Fix zero CWs in ecm.info file in case of streamrelay in use
Thx @ WXbet
oscam-git11766@77c5f266-vuplus4k_arm-webif-dvbapi-ssl-pcsc-libdvbcsa-icam.rar
(633.97 KiB) Downloaded 140 times
oscam-git11766@77c5f266-vuplus4k_armv7-webif-dvbapi-ssl-pcsc-libdvbcsa-icam-neon.rar
(621.92 KiB) Downloaded 169 times
[email protected]
(737.38 KiB) Downloaded 156 times
oscam-git11766@77c5f266-mipsoe20-webif-dvbapi-pcsc-libdvbcsa-icam.rar
(669.36 KiB) Downloaded 94 times
oscam-git11766@77c5f266-Linux-x86_64-webif-dvbapi-pcsc-libdvbcsa-icam.rar
(656.24 KiB) Downloaded 176 times
oscam-git11766@77c5f266-hd51-webif-dvbapi-ssl-pcsc-libdvbcsa-icam.rar
(607.85 KiB) Downloaded 118 times
oscam-git11766@77c5f266-dream_aarch64-webif-dvbapi-pcsc-libdvbcsa-icam.rar
(667.95 KiB) Downloaded 172 times
11768-ccb2acea6
Introduce version pipeline
- automatic tagging each commit in master branch with svn like revision number
- automatic update variable CS_SVN_VERSION in globals.h file
- adjust config.sh to read CS_SVN_VERSION from globals.h in case of non-git deployments
thanks WXbet
oscam-git11768@cb2acea6-vuplus4k_arm-webif-dvbapi-ssl-pcsc-libdvbcsa-icam.rar
(633.67 KiB) Downloaded 97 times
oscam-git11768@cb2acea6-vuplus4k_armv7-webif-dvbapi-ssl-pcsc-libdvbcsa-icam-neon.rar
(621.92 KiB) Downloaded 101 times
[email protected]
(737.04 KiB) Downloaded 102 times
oscam-git11768@cb2acea6-sh4-list_smargo.rar
(7.86 KiB) Downloaded 91 times
oscam-git11768@cb2acea6-mipsoe20-webif-dvbapi-pcsc-libdvbcsa-icam.rar
(668.65 KiB) Downloaded 116 times
oscam-git11768@cb2acea6-Linux-x86_64-webif-dvbapi-pcsc-libdvbcsa-icam.rar
(656.25 KiB) Downloaded 140 times
oscam-git11768@cb2acea6-hd51-webif-dvbapi-ssl-pcsc-libdvbcsa-icam.rar
(606.87 KiB) Downloaded 94 times
oscam-git11768@cb2acea6-dream_aarch64-webif-dvbapi-pcsc-libdvbcsa-icam.rar
(665.25 KiB) Downloaded 122 times
New Release
New Update:22.04.2024
Changeset 11769 by BuSt3D
Introduce test pipeline :
- automatic fixing trailing whitespaces on Merge Requests..
- automatic build via make and cmake + startup tests on Merge Requests..
Thx @WXBeT
oscam-git11769-801@d4a7428c-vuplus4k_arm-webif-dvbapi-ssl-pcsc-libdvbcsa-emu-icam.rar
(632.29 KiB) Downloaded 108 times
oscam-git11769-801@d4a7428c-solo4k-webif-dvbapi-pcsc-libdvbcsa-emu-icam-static.rar
(937.76 KiB) Downloaded 125 times
oscam-git11769-801@d4a7428c-sh4-webif-dvbapi-pcsc-libdvbcsa-emu-icam-static.rar
(1.37 MiB) Downloaded 106 times
oscam-git11769-801@d4a7428c-hd51-webif-dvbapi-pcsc-libdvbcsa-emu-icam-static.rar
(1.13 MiB) Downloaded 125 times
oscam-git11769-801@d4a7428c-vuplus4k_arm-webif-dvbapi-pcsc-emu.rar
(622.21 KiB) Downloaded 160 times
oscam-git11769-801@d4a7428c-vuplus4k_armv7a-webif-dvbapi-ssl-libusb-pcsc-libdvbcsa-emu-icam.rar
(610.62 KiB) Downloaded 126 times
[email protected]
(625.4 KiB) Downloaded 110 times
[email protected]
(719.77 KiB) Downloaded 136 times
oscam-git11769-801@d4a7428c-samsungtv-webif-dvbapi-pcsc-libdvbcsa-emu-icam.rar
(634.68 KiB) Downloaded 90 times
oscam-git11769-801@d4a7428c-mipsoe20-webif-dvbapi-ssl-libusb-pcsc-libdvbcsa-emu-icam.rar
(671.31 KiB) Downloaded 160 times
oscam-git11769-801@d4a7428c-mipsel-webif-dvbapi-pcsc-libdvbcsa-emu-icam.rar
(661.1 KiB) Downloaded 108 times
[email protected]
(600.89 KiB) Downloaded 99 times
oscam-git11769-801@d4a7428c-dream_arm-webif-dvbapi-libusb-pcsc-libdvbcsa-emu-icam.rar
(627.34 KiB) Downloaded 136 times
New Release
Thx @WXBeT
sh4-linux-libdvbcsa-1.1.0-32-uint32.zip
(36.92 KiB) Downloaded 137 times
mipsel-unknown-linux-gnu-libdvbcsa-lib-1.1.0-64.zip
(56.09 KiB) Downloaded 197 times
mipsel-unknown-linux-gnu-libdvbcsa-1.1.0-32-uint32.zip
(36.33 KiB) Downloaded 135 times
arm-vuplus4k-linux-gnueabihf-libdvbcsa-1.1.0-128-neon.zip
(35.33 KiB) Downloaded 97 times
armv7a-vuplus4k-linux-gnueabihf-libdvbcsa-1.1.0-128-neon.zip
(35.18 KiB) Downloaded 116 times
arm-v7a8v3r1-linux-gnueabi-libdvbcsa-1.1.0-128-neon.zip
(43.15 KiB) Downloaded 104 times
arm-unknown-linux-gnueabihf-libdvbcsa-1.1.0-128-neon.zip
(35.35 KiB) Downloaded 124 times
arm-linux-gnueabihf-libdvbcsa-1.1.0-128-neon.zip
(34.89 KiB) Downloaded 100 times
arm-dreambox-linux-gnueabihf-libdvbcsa-1.1.0-128-neon.zip
(35.33 KiB) Downloaded 116 times
Return to “Oscam”
