[Plugin] HDF-Radio
Been thanked: 1667 times
[Plugin] HDF-Radio
Update 04/12/2022
enigma2-plugin-extensions-hdfradio_1.17.5+git76+a0aab40-r1_all.ipk
admin
SF FOUNDER
SF FOUNDER
Has thanked: 1663 times
Been thanked: 422 times
Re: [Plugin] HDF-Radio
Post by admin »
Update 09/12/2022
enigma2-plugin-extensions-hdfradio_1.17.6+git79+4bd8e3a-r1_all.ipk
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Post by sugar »
Update 19/12/2022
enigma2-plugin-extensions-hdfradio_1.18.0+git83+4092f66-r1
In this version entire folders and subfolders can now be added to the playlist.
enigma2-plugin-extensions-hdfradio_1.18.0+git83+4092f66-r1_all.ipk (1.20MB)
 https://www.sendspace.com/file/k6fta0
sugar
Global Moderator
Global Moderator
Post by sugar »
Update 21/12/2022
enigma2-plugin-extensions-hdfradio_1.18.1+git86+594fe72-r1_all
enigma2-plugin-extensions-hdfradio_1.18.1+git86+594fe72-r1_all.ipk (1.20MB)
 https://www.sendspace.com/file/xc2ply
sugar
Global Moderator
Global Moderator
Post by sugar »
21/12/2022
enigma2-plugin-extensions-hdfradio_1.18.2+git87+787a0de-r1_all
The crash when calling the favorites has been fixed.
In HDF Player it is now possible to set a default folder to start in custom playlist mode.
When importing multiple folders, the sort order can now be specified.
enigma2-plugin-extensions-hdfradio_1.18.2+git87+787a0de-r1_all.ipk (1.20MB)
 https://www.sendspace.com/file/g644fp
sugar
Global Moderator
Global Moderator
Post by sugar »
23/12/2022
HDF Radio v1.18.3
1.18.3 release for python 2
1.18.3 release for python 3 version 3.9.7
1.18.3 release for python 3 version 3.10.4
1.18.3 release for python 3 version 3.11.0
enigma2-plugin-extensions-hdfradio_1.18.3_py2_all.ipk
(1.2 MiB) Downloaded 231 times
enigma2-plugin-extensions-hdfradio_1.18.3_py3_3.9.7_all.ipk
(1.21 MiB) Downloaded 202 times
enigma2-plugin-extensions-hdfradio_1.18.3_py3_3.10.4_all.ipk
(1.42 MiB) Downloaded 195 times
enigma2-plugin-extensions-hdfradio_1.18.3_py3_3.11.0_all.ipk
(1.52 MiB) Downloaded 189 times
sugar
Global Moderator
Global Moderator
Post by sugar »
25.12.2022
HDF Radio v1.18.4
1.18.4 release for python 2
1.18.4 release for python 3 version 3.9.7
1.18.4 release for python 3 version 3.10.4
1.18.4 release for python 3 version 3.11.0
All screensavers have been reworked, the song title now scrolls occasionally to prevent burn-in.
With green long (hide player) the title is now still shown in the display.
enigma2-plugin-extensions-hdfradio_1.18.4_py2_all.ipk
(1.2 MiB) Downloaded 189 times
enigma2-plugin-extensions-hdfradio_1.18.4_py3_3.10.4_all.ipk
(1.42 MiB) Downloaded 227 times
enigma2-plugin-extensions-hdfradio_1.18.4_py3_3.11.0_all.ipk
(1.53 MiB) Downloaded 175 times
enigma2-plugin-extensions-hdfradio_1.18.4_py3_3.9.7_all.ipk
(1.21 MiB) Downloaded 211 times
sugar
Global Moderator
Global Moderator
Post by sugar »
28.12.2022
HDF Radio v1.18.5
1.18.5 release for python 2
1.18.5 release for python 3 version 3.9.7
1.18.5 release for python 3 version 3.10.4
1.18.5 release for python 3 version 3.11.0
In the HDF player you can now select the gstplayer as music player.
This should fix some problems with MP3 and small dropouts.
The languages got an update.
The processing of cue files has been improved.
enigma2-plugin-extensions-hdfradio_1.18.5_py2_all.ipk
(1.21 MiB) Downloaded 214 times
enigma2-plugin-extensions-hdfradio_1.18.5_py3_3.9.7_all.ipk
(1.22 MiB) Downloaded 211 times
enigma2-plugin-extensions-hdfradio_1.18.5_py3_3.10.4_all.ipk
(1.44 MiB) Downloaded 197 times
enigma2-plugin-extensions-hdfradio_1.18.5_py3_3.11.0_all.ipk
(1.54 MiB) Downloaded 175 times
sugar
Global Moderator
Global Moderator
Post by sugar »
HDF Radio v1.19.0 - 30.12.2022
1.19.0 release for python 2
1.19.0 release for python 3 version 3.9.7
1.19.0 release for python 3 version 3.10.4
1.19.0 release for python 3 version 3.11.0
The gstplayer can now also be used in the radio.
If there are problems with the speed, then the information and covers can be disabled.
In the radio, the favorites can now be added to other favorites with the 8 key.
So you can copy an already existing station from one list to another.
In the Favorites Editor, the EPG key can now be used to change the favorites in editing.
Also there you can copy already existing channels to other lists.
The last translations have been added. However, some new text has been added.
The translators would have to do it again.
2, 3 small bugs have been fixed.
enigma2-plugin-extensions-hdfradio_1.19.0_py2_all.ipk
(1.21 MiB) Downloaded 245 times
enigma2-plugin-extensions-hdfradio_1.19.0_py3_3.9.7_all.ipk
(1.22 MiB) Downloaded 193 times
enigma2-plugin-extensions-hdfradio_1.19.0_py3_3.10.4_all.ipk
(1.44 MiB) Downloaded 182 times
enigma2-plugin-extensions-hdfradio_1.19.0_py3_3.11.0_all.ipk
(1.55 MiB) Downloaded 241 times
sugar
Global Moderator
Global Moderator
Post by sugar »
HDF Radio v1.19.1 - 06.01.2023
1.19.1 release for python 2
1.19.1 release for python 3 version 3.9.7
1.19.1 release for python 3 version 3.10.4
1.19.1 release for python 3 version 3.11.0
-The loading times of the covers on the radio have been optimized.
-The determination of the covers was moved to a separate thread to avoid spinners.
-The search for stations in the radio was extended and improved.
-Some more bugs were fixed.
enigma2-plugin-extensions-hdfradio_1.19.1_py2_all.ipk
(1.22 MiB) Downloaded 235 times
enigma2-plugin-extensions-hdfradio_1.19.1_py3_3.9.7_all.ipk
(1.22 MiB) Downloaded 206 times
enigma2-plugin-extensions-hdfradio_1.19.1_py3_3.10.4_all.ipk
(1.45 MiB) Downloaded 194 times
enigma2-plugin-extensions-hdfradio_1.19.1_py3_3.11.0_all.ipk
(1.56 MiB) Downloaded 225 times
