YouTube Vanced
YouTube Vanced
YouTube Vanced v17.03.38 [Vanced2Original] [NON-ROOT]
Requirements: 6.0+
Overview: Enjoy your favorite videos and channels without ADS and with Background Play on this YouTube app.
Features:
No root needed to install
No need to uninstall official YouTube, can install as a secondary YouTube.
Works on a Chromecast.
Whole new ad blacking method
Simplified mod to enable background playback
Enable/Disable background playback via Settings
Force VP9 Codec option for better video quality and lesser bandwidth usage (Settings -> IYTBP Settings)
Override Max Resolution Limit (Settings -> IYTBP Settings)
Preferred Video Quality switch (WiFi/Data) (Settings -> IYTBP Settings)
Enable/Disable Info Cards on videos (Settings -> IYTBP Settings)
Enable/Disable Suggestions Cards on videos (Settings -> IYTBP Settings)
Enable/Disable channel branding watermark on videos (Settings -> IYTBP Settings)
Pinch to zoom enabled on all devices
With the help of modded microG, Login & Casting works with all features (no ads on external devices not guaranteed)
Main changes:
• Bumped base
• ReturnYouTubeDislike integration (closes #1394)
• Channel whitelisting for video ads
• Improved ad-blocking
• Comments location (alpha) has been removed (because Google pushed new comments to tablet UI)
• Added tablet style under swipe controls for partially disabling recommended videos in landscape mode and other tablet styled UI
• Added support for themed icon (Android 13+)
Sponsorblock changes:
• added support for channel whitelisting (see the "Channel whitelisting" toggle in sb settings)
• added support for setting the minimum segment duration
• added the filler category
• replaced the "Change colors" button with a text field inside of each category's setting
• 403 messages (warns, locked video/segment) will now be properly displayed
• added an option to enable SB browser button.
• option to change the API URL
KNOWN ISSUES
• On new action bar layouts(server-sided feature), the new toggles won't work.
• all the usual previous issues relating to Chromecast, codec override and swipe down gesture to refresh.
PLANNED CHANGES FOR NEXT RELEASE
• Option to make SponsorBlock submitting and voting buttons appear under the video
• make RYD work in all layouts
• add more ad whitelist options such as viewing the entire list of whitelisted channels and a global video ads toggle
• Standalone Android Package
• No need to install from SAI or Lucky Patcher
• No need to turn off MIUI optimization in MIUI roms
★★★ Vanced2Original [NON-ROOT] by CaM/7oCe6e ★★★
Description:
- Original splash
- Original name
- Original icon
- Added the ability to run the application without microG installed.
- No inscription in some videos in the upper left corner "There are ads."
- Added the ability to remove the "Create" shorts button under the video. (thanks to Antonbeard for the code)
- Added the ability to disable dimming on pause.
- Added ability to switch PowerTube/YouTube Downloader video downloader.
- Added ability to bypass youtube.com/redirect when opening links.
Languages: Full Multi Languages
CPUs: armeabi-v7a + arm64-v8a
• Install Youtube Vanced
• Install MicroG
• Open Youtube Vanced
• Log In to your Account
Note: You must enable the Dark theme in the settings
http://ul.to/ml0b0zrq
