Eva IpTv v1.25 [Mod]
Been thanked: 1028 times
Overview: Watch IPTV channels from your service provider or free channels from any source available on the web.
How to use the app:
- Select the + icon to add lists
- select Add Url or Add Code and enter the data, select ok to confirm the entry
- you can change the name of the list if you wish
- return to the home menu and update all lists with the Update All Lists button or the selected list by long-pressing the list name
The application supports Exoplayer, Vlc player, Mx player and picture in picture for viewing up to 4 streams at a time
What's new:
- Added players
Package Info:
● Supported Languages: af, am, ar, as, az, be, bg, bn, bs, ca, cs, da, de, el, en-AU, en-CA, en-GB, en-IN, en-XC, es, es-US, et, eu, fa, fi, fr, fr-CA, gl, gu, hi, hr, hu, hy, in, is, it, iw, ja, ka, kk, km, kn, ko, ky, lo, lt, lv, mk, ml, mn, mr, ms, my, nb, ne, nl, or, pa, pl, pt, pt-BR, pt-PT, ro, ru, si, sk, sl, sq, sr, sr-Latn, sv, sw, ta, te, th, tl, tr, uk, ur, uz, vi, zh-CN, zh-HK, zh-TW, zu;
● Supported CPU architecture: None;
● Supported Screen DPI: Ldpi, Mdpi, Tvdpi, Hdpi, Xhdpi, Xxhdpi, Xxxhdpi.
Mod Info:
● Ads Removed / Disabled.
● Receivers and Services Removed / Disabled.
● Google Play Store Install Package Check Disable.
● Duplicate Dpi Item Remove Like:
● Splits0 File Removed (Resources & AndroidManifest).
● Splits0 Releated Unnecessary Meta-Data Remove Like:
● Optimized PNG Save To 530 Kb.
● Optimized JPG Save To 81 Kb.
● Re-Compressed Classes.dex & Library.
● Optimized Graphics / Zipalign.
● Removed Annotation Code.
● Total Apk Size 9.08 Mb.
http://ul.to/7eem2mv8
