Adguard - Block Ads Without Root v3.6.46 [Final] [Premium] [Mod Lite]
Overview: THE WORLD'S MOST ADVANCED AD BLOCKER!
AdGuard is the best way to get rid of intrusive ads and online tracking, and to protect your device from malware.
Make your web surfing faster, safer and more comfortable with AdGuard!
AdGuard is a unique no root ad blocker for Android that removes ads in apps and browsers, protects your privacy, and helps you manage your apps
Easy to set up and get going, but powerful and highly customizable — it has everything you'll ever need from an Android adblock tool, and it works both on rooted and unrooted devices.
Why choose AdGuard?
Blocks ads everywhere
Block throughout the whole system. This includes video ads and ads in your favorite apps, browsers, games, and on any website you can imagine. Dozens of ad filters are available to you and are updated on a regular basis, guaranteeing the best filtering quality.
Cares about your privacy
We value the privacy of your personal data above anything else. With AdGuard, you will be safe from online trackers and analytics systems that lurk on the web trying to steal your sensitive information.
Saves your traffic
More ads blocked means fewer ads loaded. Fewer ads loaded means more traffic saved. Simple math by AdGuard! Download the apk file, install the app and spend your traffic on things you like instead of wasting it on voracious ads.
You stay in control
It is your device, after all, and you decide what gets filtered and what doesn’t. A wide range of settings — from basic to 'pro' — as well as an Apps Management tool will help you customize the filtering to your liking.
Try AdGuard ad blocker for Android apps for free and feel the difference! Once you go with our app on your tablet or mobile phone, you'll never want to go back.
In this version we've added a new feature — 'Protect from DPI'. In a nutshell, it modifies your outgoing traffic to prevent ISP's Deep Packet Inspection systems from detecting the websites you visit. To make this feature visible and enable it, select 'Custom' in the Stealth Mode tab and scroll down.
Besides, we've fixed extensions settings and enabled HTTPS filtering by default for Naver Whale Browser. Finally, CoreLibs and DnsLibs were updated.
Changelog
[Fixed] AdGuard not turning on inside Samsung secure folder, Android 12;
[Fixed] Replace the "Move certificate" with "AdGuard certificate" as a recommended Magisk module;
[Fixed] Check "pref.dns.blocking.type" translations, they seem to be outdated;
[Fixed] The URL in about wrongly includes the front words (zh-TW);
[Fixed] Make sure that we open proper settings section when installing a certificate on Samsung devices;
[Fixed] Add an DPI-bypass option to AdGuard Stealth Mode;
[Other] Update CoreLibs and DnsLibs to their latest versions.
Mod Info:
Based on default Mod Version;
Optimized and zipaligned graphics and cleaned resources for fast load - [13.9 Mb total apk size];
Languages: En, Ru;
CPUs: armeabi-v7a, arm64-v8a;
Screen DPIs: 120dpi, 160dpi, 240dpi, 320dpi, 480dpi, 640dpi;
Original package signature changed;
Release by Balatan.
http://ul.to/ju78sluc
