Smart IPTV Xtream Player
Been thanked: 1028 times
Smart IPTV Xtream Player v4.0 b65 [AndroidTV/Mobile] [Ad-Free +]
Overview: Stream all your IPTV content from your service provider
-Support: XTREAM-CODES API
-Support M3u line
-Support Chrome Cast
-Multi User Support
-Parental Control Support
-Recording support
-External Player Support.
-Favorites Support
-Playlist Support (self Manage Support)
-Theme Support
-Multiple Language Support
-One of the best features of this app is to get the content categorized into the group like Movies, Series, live, catch up separately.
-Search Functionality.
-Sorting Functionality (with Default A-Z, Z-A, Top-Added, Last Modified)
-Movies Info & Rating and other info.
-All standard Codec’s and Format are supported.
-Impressive & Attractive UI.
-Easy to use.
-Small in size.
-Fast, Reliable and Robust.
Warning
-Only support android device above 4.4 kitkat i.e start supporting lollipop
Disclaimer:
-IPTV Xtream Player does not supply or include any media or content
-Users must provide their own content
-IPTV Xtream Player has no affiliation with any third-party provider what so ever.
-We do not endorse the streaming of copyright-protected material without permission of the copyright holder.
VERSION 4.0 b65 April 7, 2022
-Fixed EPG Issue
-Improvement
-Bug Fixes
Tested On OnnBox, Gen2FS, Gen3FS, SmartFireTV, SmartAndroidTV,3 Older Boxes, 6,7,8,9,10 Phones & 2 Tablets
No Mouse Toggle Needed
Will Install Over My Previous Only!
Force Stop Previous/Clear Cache Only!
*Not Supported By All Service Providers
**For Me Only Supported By 2 Out Of 3
As Of This Release
*Note Default Player Setting Is Set To Native & Does Not Work On My End
Change To Default Or Desired Installed Player
Ad-Free + Info:
Location removed
Ads patched/disabled
Ad permissions disabled
Google play billing removed
Run at startup removed(request)
Advertising ID permission removed
Asset folder cleaned per Arm version
Audience network disabled/Dex removed
Read calendar events + confidential info removed
Add/modify calendar events & send email to guests without owner's knowledge removed
*Some devices may force close 1st run due to run at startup removed by request(just relaunch)
http://ul.to/fs817em7
