X-Streamity
- adrianoluis
- Developer
- Has thanked: 7 times
- Been thanked: 1029 times
X-Streamity
X-Streamity - Xtream Codes IPTV Player
XStreamity 3.64
-New VOD Downloader
also forced domains to be lowercase. Might eliminate some problems mentioned of late.
XStreamity 3.64
-New VOD Downloader
- Has thanked: 14359 times
- Been thanked: 1668 times
Re: X-Streamity
Xstreamity V3.66
Fixed lag on scrolling through categories - I was clearing cache on selection change instead of load. Should now be fast to scroll and fast load images again.
Removed some other cache clearing from certain places. Main menu, playlist menu etc.
Removed some unnecessary duplicate code on playlist settings (or at least I think its unnecessary). Might fix peoples disappearing playlists. Then again it might not.
Fixed manually adding lines via the plugin - problem ones were ones that redirected. This should now be fixed and no need to add via playlists.txt instead
Streamplayer
Cache is now cleared after 10 minutes and not every minute
Better failed stream handling. After 7 seconds, it tries stream again. After another 7 seconds it will switch 1 to 4097 or 4097 to 1. 5001 stays as 5001 as that should play if the stream is valid.
Streamplayer
- admin
- SF FOUNDER
- Has thanked: 1662 times
- Been thanked: 422 times
Re: X-Streamity
XStreamity V3.67
Fix epg importer channel file
Changed the download.json file name to download2.json to prevent clashes with older versions.
Amended a few more url downloads to prevent a redirect issue
Updated all the po translation files from my source files - feel free to fill in the gaps if you are bored this weekend
Removed some more cache clearing
Fixed a wrongly named variable in streamplayer that might have caused a crash.
General code cleanup.
Always Press THANKS button
- adrianoluis
- Developer
Re: X-Streamity
XStreamity 3.69
-Reverted my timeout changes that were causing some people issues
-Added in the extra German trranslations
- adrianoluis
- Developer
Re: X-Streamity
- enigma2-plugin-extensions-xstreamity_4.16.20230924_all.ipk
- (5.48 MiB) Downloaded 147 times
- adrianoluis
- Developer
Re: X-Streamity
X-Streamity - Official Release.
V 4.38- 24/02/2024
french, italian, spanish translation updates
V 4.38- 24/02/2024
- enigma2-plugin-extensions-xstreamity_4.38.20240224_all.ipk
- (4.25 MiB) Downloaded 144 times
Re: X-Streamity
XStreamity v4.39
Allow future live recordings to be saved on a reboot
Thanks KiddaC
Thanks KiddaC
- ocean777
- Has thanked: 240 times
- Been thanked: 210 times
Re: X-Streamity
V 4.40- 10/03/2024
thx KiddaC
V 4.40- 10/03/2024
thx KiddaC
- enigma2-plugin-extensions-xstreamity_4.40.20240310_all.rar
- (4.25 MiB) Downloaded 117 times
- ocean777
Re: X-Streamity
Xstreamity v4.41
- enigma2-plugin-extensions-xstreamity_4.41.20240502_all.rar
- (4.26 MiB) Downloaded 68 times
- ocean777
Re: X-Streamity
X-Streamity-V4.42
Thx @KiddaC
Thx @KiddaC
- enigma2-plugin-extensions-xstreamity_4.42_20240506_all.zip
- (3.91 MiB) Downloaded 76 times
- enigma2-plugin-extensions-xstreamity_4.42.20240506_all.zip
- (4.26 MiB) Downloaded 90 times
