EaseUS Partition Master
EaseUS Partition Master 16.8 All Editions Multilanguage
EaseUS Partition Master is an all-in-one partition solution and disk management software. It allows you to extend partition (especially for system drive), manage disk space easily, solve low disk space problem on MBR and GPT disk.
Supported Operating System:
Windows 11/10/8/7
Supported File System:
NTFS/EXT4/EXT3/EXT2/FAT32/FAT16/FAT12/ReFS
Hardware Requirements
CPU: at least with X86 or CPU compatible with 500MHz main frequency
RAM: equal to or greater than 512MB
Disk Space: Hard disk drive with 100MB available space
File size: 68.6MB
http://ul.to/186s5bwi
