Notepad++ [*.Latest version] 👈🏽🔰🔰✅
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Post by sugar »
Notepad++ v8.4 Release​
New update:26.04.2022
1.Fix crash regression on opening a session file.
2.Enhance stability: add new ability (plugin compatibility) for not loading incompatible plugins.
3.Fix deleting the folded line makes folded (hidden) content disappeared.
4.Re-enable ability to center the FindReplaceDlg on Notepad++ main window.
5.Fix extension not appended issue while saving with ENTER under Windows 7.
6.Fix preferences dialog "Dark Mode->Customize tone" RTL alignment issue in dark mode.
7.Fix disabled static texts of Preferences blurry issue in Dark mode.
8.Add 4 API for custom auto-indentation and getting current macro status.
9.Add new AutoComplete icon for distinguishing functions from normal keywords.
10.Fix Plugin Admin close issue after typing ENTER.
11.Show current and new version on update dialog.
Download Notepad++ v8.4
sugar
Global Moderator
Global Moderator
Re: Notepad++ [*.Latest version] 👈🏽🔰🔰✅
Post by sugar »
Notepad++ v8.4.1 Release (2022-05-11)
1.Fix HTML syntax highlighting in PHP files regression.
2.Fix "Reload from disk" loosing syntax highlighting regression.
3.Fix unfocused selected text background color changed regression.
4.Update Scintilla from 5.2.1 to 5.2.2 and Lexilla from 5.1.5 to 5.1.6.
5.Fix multi-part keyword in prefix mode freezes Notepad++ in UDL.
6.Add several dark mode enhancement.
7.Add DarkMode usage detection support for plugins.
8.Add "Framed current line" option beside of "Highlight current line background".
9.Add file monitoring command line argument [-monitor].
10. Add File Dialog enhancement.
11.Add a new format argument/option "ADD_ZERO_PADDING" to NPPM_GETNPPVERSION.
12.Restore auto-completion & calltip default fg/bg colors when no theme is applied.
13.Sort "Search result" to the bottom in language list of Style Configurator.
Download Notepad++ v8.4.1
sugar
Global Moderator
Global Moderator
Post by sugar »
Notepad++ v8.4.2 Release (2022-06-03)
1. Fix crash on "Copy Binary Content" command without selection on edit zone.
2. Fix crash by re-invoking with command line argument "-udl".
3. Make toolbar icons customizable.
4. Make fold/unfold current level commands toggleable.
5. Add command line argument for plugin, a related notification and an API.
6. Fix horizontal scrolling with scroll wheel on Logitech MX issue.
7. Enhance dark mode.
8. Add encoding context menu via right/double click on status bar.
9. Add gui4cli keywords and fix its style IDs in stylers.model.xml.
10. Display installed plugin versions in Debug Info dialog.
Download Notepad++ v8.4.2
sugar
Global Moderator
Global Moderator
Post by sugar »
Fix crash on “Copy Binary Content” command without selection on edit zone.
Fix crashes by re-invoking with command line argument “-udl”.
Enhance dark mode.
Download Notepad++ v8.4.2 | Notepad++
https://notepad-plus-plus.org/downloads/v8.4.2/
sugar
Global Moderator
Global Moderator
Post by sugar »
Notepad++ v8.4.6 Released
New update:29.09.2022
1. Add Change History markers for document saved/unsaved/undone modification.
2.Add setting tab color ability.
3.Update to Scintilla 5.3.0 and Lexilla 5.1.9
4.Fix "Never" button not showing on Updater dialog regression.
5.Fix a printing selection regression.
6.Revamp tab context menu: make it less cluttered by adding sub-menu.
7.Fix a security vulnerability.
8.Add dark mode support to Choose Color dialog.
9.Add a page (tab) for incompatible (unloaded) plugins in Plugin Admin.
10.Add Plugin list repository link and its version in PluginAdmin dialog.
11.Fix horizontal bar showing issue while resizing document list's height.
12.Fix NPPN_DARKMODECHANGED wrong return value to plugins.
https://notepad-plus-plus.org/downloads/v8.4.6/
zapppa
Has thanked: 43 times
Been thanked: 86 times
Italy
Post by zapppa »
Where i can find plugins?
sugar
Global Moderator
Global Moderator
Post by sugar »
Notepad++ v8.4.7 Released
Fix empty session issue due to forced Windows update restart.
Fix printing with extra background colors issue due to Change History.
Update to scintilla 5.3.1 and lexilla 5.2.0.
Updated nlohmann json to 3.11.2 and boost to 1.80.0.
Make large file restriction configurable.
Optimize open/save large files time.
Remember Column Editor settings through the sessions.
Fix plugin admin search issue.
Installer enhancement: prevent arm64 installer from installing on non ARM64 system.
Installer enhancement: remember “Don’t use_%APPDATA%” option.
Add new API NPPM_GETBOOKMARKID for getting bookmark ID.
Enhance “Go To” dialog: update line/position data dynamically.
Fix lines hiding issue.
Fix language detected from content not applied if default language is set.
Fix long filters get truncated in Find in Files feature.
Add ESC Key for aborting “Move to Recycle Bin” confirmation prompt.
Downloads/v8.4.7
https://notepad-plus-plus.org/downloads/v8.4.7/
sugar
Global Moderator
Global Moderator
Post by sugar »
Notepad++v8.5 Release
New update:06.03.2023
1.Fix notepad replacement opening file name containing white space regression.
2.Fix regression about visual glitch of Find in Files progress window & Document Switcher.
3.Update to Scintilla 5.3.3 and Lexilla 5.2.2.
4.Add new explorer context menu entry "Edit with Notepad++" for WINDOWS 11.
5.Add show non-printable characters command.
6.Apply tab colors to document list items, and add groups to document list.
7.Add middle mouse click ability to close doc in Document List.
8.Add Begin/End Select in Column Mode command.
9.Add option to make auto-completion list brief.
10.Remove duplicate items in function/word list of Auto-completion.
11.Fix missing items in word autocomplete.
12.Fix autocomplete to sort case insensitive issue.
13.Fix wrong value set in Preferences->Performance->"Define Large File Size".
14.Change behaviour: make Select and Find (Next/Previous) always in normal search mode.
15.Change behaviour: make volatile Find uses least-strict option settings.
16.Change behaviour: don't populate in Find what if a stream selection more than 1024 characters.
17.Fix dock-able panels not restoring for mono instances when Notepad++ is in the tray.
18.Fix panels not restored from systemtray with "Edit with Notepad++" in admin mode.
19.Fix hit text in search results not being scrolled in the view issue.
20.Fix untitled document number jumping or repeated problem.
21.Add new notification NPPN_EXTERNALLEXERBUFFER for lexer plugin with buffer ID when a new lexer is applied to the buffer in question.
22.Fix Synch H/V Scrolling commands not sync with 2 views.
23.Add several GUI enhancement.
24.Make several GUI items translatable.
Download Notepad++ v8.5
https://notepad-plus-plus.org/downloads/v8.5/
sugar
Global Moderator
Global Moderator
Post by sugar »
Notepad++ v8.5.1 Release
New update: 24.03.2023
1. Use new modern shell "Edit with Notepad++" of Windows 11 instead of hijacking "Pin to Quick access".
2. Update scintilla to 5.3.4 and lexilla to 5.2.4.
3. Add MS Transact-SQL support.
4. Add GDScript language support with autocomplete & functionlist.
5. Fix UDL empty button regression after changing localization.
6. Add ability to copy "Find what" to "Replace with" and vice versa in Find Replace dialog.
7. Fix DocSwitcher RTL problem, and use edit field instead of a small popup value dialog.
8. GUI visual enhancement: Fix whole dialog items blink when a item value changed.
9. Make tray icon context menu translatable.
Download Notepad++v8.5.1​
https://notepad-plus-plus.org/downloads/v8.5.1/
sugar
Global Moderator
Global Moderator
Post by sugar »
Notepad++ v8.5.4 Release
New update:18.06.2023
1. Fix macro recording regression on Unicode character.
2. Fix regression of defective detection for file read-only attribute removal via Explorer.
3. Fix opening multi-files on multi-instance mode regression.
4. Update: Scintilla 5.3.5 Lexilla 5.2.5
5. Fix Notepad++ hanging issue running macro to EOF.
6. Fix EOL symbol color/appearence being reset issue while changing encoding.
7. Enable code folding in Assembly source files.
8. Fix document language not remembered through sessions issue.
9. Add SHA-1 hash features.
10. Add "open new blank document in addition on startup" ability.
11. Fix lexer plugin is sorted unconventionally in language menu issue.
12. Add message NPPM_DARKMODESUBCLASSANDTHEME to allow plugin to use generic dark mode.
13. Add the ability to close multiple files without saving in Document list.
14. Several GUI Enhancements.
15. Fix tabContextMenu_example.xml not being deleted while uninstallation.
16. Fix error message on uninstallation.
Download Notepad++ v8.5.4
https://notepad-plus-plus.org/downloads/v8.5.4/
