[Plugin] OpenWebif
Has thanked: 14324 times
Been thanked: 1623 times
[Plugin] OpenWebif
Version 1.5.0 with Latest Fixes
-Tweaks
* Remove picon & button actions from sub-bouquet name
* Add text to advise that most browsers no longer support this
-Update hd51 imagery
* Update hd51 stb imagery to replace monochromatic version
* Update hd51 stb imagery to replace terrible vfd display font
-Optimise box images (transparent PNG format)
-Optimise stb & remote imagery
* Optimise box images
This change:
- saves **~3MB** of space
- converts png files to jpg
- crops out excess padding
- applies PNGOUT, OxiPNG and AdvPNG, JPEGOptim and Jpegtran optimisations and strips metadata via ImageOptim
- sets a max width of 1000px to a small number of images
* Optimise remote images
https://www.mediafire.com/file/yvr4hlin ... b.rar/file
https://www.mediafire.com/file/t2wh5gvp ... k.rar/file
https://www.mediafire.com/file/o9xb0g8o ... k.rar/file
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Re: [Plugin] OpenWebif
Post by sugar »
- Bugfix EPG current time bar colour
- Bugfix header search This change: fixes initial header epg search
-Rudimentary Now/Next sub-bouquet functionality
-This change facilitates drilling down into sub-bouquets
- This change does not fully implement sub-bouquets
- enigma2-plugin-extensions-openwebif latest all.ipk
https://sbupload.com/49cdbd8980d8108d
- enigma2-plugin-extensions-openwebif latest all.deb.
https://sbupload.com/77a900c7b3ce1f9d
- enigma2-plugin-extensions-openwebif latest vti.ipk.
https://sbupload.com/ed9245da9e7c077f
sugar
Global Moderator
Global Moderator
Post by sugar »
08.05.2022
Version 1.5.1 with Latest Fixes
-Move screenfull lib to npm
-CI / npm add semver
-Commit overlooked lockfile
-Fix degree character encoding
-Bugfix - WOL TypeError
This change also tidies response bodies and capitalises response headers.
..........and many other fixes
https://www.mediafire.com/file/qx1z3rdh ... k.rar/file
https://www.mediafire.com/file/al8u46bb ... k.rar/file
https://www.mediafire.com/file/u5o03ym0 ... b.rar/file
OpenWebif Plugin...04/06/2022
- e2openplugin-OpenWebif
- Version 1.5.1
- with Latest Fixes
- Move package version details into About OpenWebif page..
This change moves package version details from hidden-by-default side menu item into always-visible `About OpenWebif` page
-Fix capitalisation.
- enigma2 plugin extensions openwebif 1.5.1 git20220604-r2 all.ipk
https://sbupload.com/f63956cf55e29808
- enigma2 plugin extensions openwebif 1.5.1 git20220604-r2 vti.ipk.
https://sbupload.com/7b456d95b556b280
enigma2-plugin-extensions-openwebif_1.5.1-git20220604-r2_all.deb.rar
(3.45 MiB) Downloaded 151 times
sugar
Global Moderator
Global Moderator
Post by sugar »
sugar
Global Moderator
Global Moderator
Post by sugar »
OpenWebif Plugin..23/06/2022
- V 1.5.1 with Latest Fixes
-Fix initial selection of `Packages` option
-Fix duplicated ' replace
- enigma2 plugin extensions openwebif 1.5.1 git20220623-r3 all.ipk
https://sbupload.com/f2c9d48d151f86fa
- enigma2 plugin extensions openwebif 1.5.1 git20220623-r3 vti.ipk.
https://sbupload.com/2c180b81df16415e
- enigma2 plugin extensions openwebif 1.5.1-git20220623-r3 all.deb.
https://sbupload.com/529a1bb4358fdc47
sugar
Global Moderator
Global Moderator
Post by sugar »
02.07.2022
Text tweak (`Open Webif` -> `OpenWebif`)
allow also showOpenWebif in setup.xml because this is the correct name
enigma2-plugin-extensions-openwebif_1.5.1-git20220702-r4_vti.ipk.rar
(4.65 MiB) Downloaded 111 times
enigma2-plugin-extensions-openwebif_1.5.1-git20220702-r4_all.ipk.rar
(12.23 MiB) Downloaded 120 times
enigma2-plugin-extensions-openwebif_1.5.1-git20220702-r4_all.deb.rar
(3.45 MiB) Downloaded 115 times
sugar
Global Moderator
Global Moderator
Post by sugar »
20.07.2022
Version 1.5.2 with Latest Fixes
-[file.py] FileController must return bytes
Fix reading files with python3.
-[info.py] fix typo
-One more tiny optimization for getMultiEpg
enigma2-plugin-extensions-openwebif_1.5.2-git20220720-r2_all.ipk.rar
(12.24 MiB) Downloaded 127 times
enigma2-plugin-extensions-openwebif_1.5.2-git20220720-r2_all.deb.rar
(3.45 MiB) Downloaded 416 times
sugar
Global Moderator
Global Moderator
Post by sugar »
22.07.2022
-Update it.po
-Update npm sass
-Update github action
* move build.sh from py2.7 to py 3.9
-Bump terser from 4.8.0 to 4.8.1 in /sourcefiles/modern
-autopep8 add E261, E262
-Fix sass build and mincss.js
enigma2-plugin-extensions-openwebif_1.5.2-git20220722-r10_all.ipk.rar
(12.44 MiB) Downloaded 123 times
enigma2-plugin-extensions-openwebif_1.5.2-git20220722-r10_all.deb.rar
(3.45 MiB) Downloaded 127 times
sugar
Global Moderator
Global Moderator
Post by sugar »
10.08.2022
-Update
-Revert change which broke MultiEPG timebar in modern interface
enigma2-plugin-extensions-openwebif_1.5.2-git20220810-r3_all.ipk.rar
(12.46 MiB) Downloaded 132 times
enigma2-plugin-extensions-openwebif_1.5.2-git20220810-r3_all.deb.rar
(3.45 MiB) Downloaded 134 times
