Ncam 13.3
Has thanked: 14324 times
Been thanked: 1623 times
Ncam 13.3
Ncam 13.3
-NEON is now used for ARM CPUs. These are special parts of the CPU that can execute certain code faster. This helps with decryption. From my point of view, the load on my sf8008 drops a bit. If you want to compare it, then always with the same station and preferably the same show. The load varies greatly from transmitter to transmitter. This means that 128 packets are decrypted at the same time and not 32 as before.
As far as I've read, Mipsel Broadcom boxes don't have this type of processing. With Mipsel I wouldn't use Radegast (if possible) and I wouldn't even compile it at all (Thanks to icb)
- When zapping to a station with a pause, you don't have to wait for the 30 second timeout before the tuner is released again (Thanks to icb)
- Optimization mostly for MIPS boxes (Thanks to icb)​
NCam-Images-OSDreambox-DEB.zip
(3.09 MiB) Downloaded 79 times
ncam-router.mips.zip
(898.12 KiB) Downloaded 68 times
Ncam-Images-IPK.zip
(4.93 MiB) Downloaded 70 times
ncam.x86_64.zip
(870.92 KiB) Downloaded 71 times
ncam.x86.zip
(916.48 KiB) Downloaded 72 times
ncam.sh4-stapi.zip
(940.96 KiB) Downloaded 82 times
ncam.sh4-Cardiff-stapi5_V03.zip
(947.93 KiB) Downloaded 69 times
ncam.sh4-Cardiff-stapi5.zip
(948.17 KiB) Downloaded 76 times
ncam.arm-androideabi19-4.4_KitKat-stapi.zip
(1.62 MiB) Downloaded 69 times
ncam.arm-android_7.0-Nougat-stapi.zip
(1.61 MiB) Downloaded 75 times
ncam.arm-android_6.0-Marshmallow-stapi.zip
(1.61 MiB) Downloaded 74 times
ncam.arm-android_5.1-Lollipop-stapi.zip
(1.62 MiB) Downloaded 77 times
ncam.arm-android_5.0-Lollipop-stapi.zip
(1.62 MiB) Downloaded 78 times
ncam.android_Icone-Iron-stapi.zip
(1.77 MiB) Downloaded 75 times
zapppa
Has thanked: 43 times
Been thanked: 86 times
Italy
Re: Ncam 13.3
Post by zapppa »
I have 13.2
I need to update?
Return to “Other Cardsharing Emulators”
