Latest Version of FileZilla
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Been thanked: 1672 times
Post by sugar »
FileZilla Client 3.56.2 Released-(2021-10-27)
Bugfixes and minor changes:
Updated to libfilezilla 0.34.0
Updated translations
Download FileZilla Client 3.56.2 Released
sugar
Global Moderator
Global Moderator
Re: 🔰 Latest Version of FileZilla 👈🏽🔰🔰✅
Post by sugar »
FileZilla Client 3.59.0-rc1 Released-(2022-04-01)
-Updated to libfilezilla 0.37.0
-Non-blocking communication with SFTP process
-macOS, *nix: Fixed "All files" category in file picker dialogs
sugar
Global Moderator
Global Moderator
Post by sugar »
FileZilla Client 3.59.0 Released-(2022-04-08)
Windows binaries: Updated zlib, used purely to cache re-scaled versions of icons shipped with FileZilla, to 1.2.12
Updated to libfilezilla 0.37.1
sugar
Global Moderator
Global Moderator
Post by sugar »
FileZilla Server v1.4.0-rc1 Released​
New Update:20.04.202
-MSW: The installer not detects and rejects 32bit Windows..
-MSW, Admin UI: No more double error message when a validation error occurs..
-Admin UI: Solved a crash and fixed other bugs related to minimzing the main window to the notification area..
S-erver: --write-config option now also updates the users and groups configuration files..
-Server: the log contains more detailed info about which configuration files have been saved..
-Admin UI: the controller used for editing numbers now correctly accepts negative integers..
-The network config wizard's text has been updated to be more explanatory and intuitive..
-Self signed certificates don't require a 2nd level domain anymore..
-Admin UI: the system user is now always at the top..
-Admin UI: more meaningful message if the password is empty..
-Admin UI: message dialogs now always have a reference to the top window..
F-TP: QUIT needs to respond with 221, not 200..
-Bug fixes to the internal HTTP library..
-MSW: the installer now correctly displays the progress bar in all cases..
-Fixed a confusing error message in some situations if trying to list non-existing directories..
sugar
Global Moderator
Global Moderator
Post by sugar »
FileZilla Server v1.4.0 Released-(2022-04-29)
    -Debian: by default the service is now configured to exclude headers from log lines, since journald outputs its own headers already.
    -Mac: fixed regression that made the installed service not startable
    -Admin UI: changed wording in the logging settings
    -Admin UI: made default connection values correct, in case the settings file is missing.
    -MSW: fixed various bug in the ExecDos plugin, that could cause the admin password not to be set properly.
    -MSW: non-ASCII admin passwords can now be properly used.
    -MSW: fixed a bug in libfilezilla that caused an unexpected failure when creating directories with restricted access. It had effects on the ACME account creation.
sugar
Global Moderator
Global Moderator
Post by sugar »
FileZilla Server v1.4.1 Released-(2022-05-06)
-Admin UI: Fixed a crash on the listener page.
-Admin UI: Improved workflow for changing user passwords.
-MSW: Fixed an issue with the converter for configurations from FileZilla Server 0.9.***.
Download FileZilla Server 1.4.1
sugar
Global Moderator
Global Moderator
Post by sugar »
The latest stable version of FileZilla Client is 3.60.1
https://filezilla-project.org/download.php?show_all=1
sugar
Global Moderator
Global Moderator
Post by sugar »
FileZilla Server v1.5.0-rc1 Released-(2022-07-12)
-Admin UI: Fixed a crash in listener editor..
-Admin UI (macOS): Implemented workarounds for some wxWidgets glitches and malfunctions..
-Admin UI: The system_user's name cannot be edited anymore (rightly so)..
-Configuration data that cannot be serialized now prevents an incomplete output file from being written to disk..
-Sudden deaths of the impersonator process no longer cause unintended behavior
-Fixed server crashes due to unexpected socket events in some corner cases
-MSW: Due to a toolchain issue, programs making use of thread-local variables would crash on exit. Implemented a workaround, until it gets addressed by future MinGW toolchains..
-The number of possible worker threads has been reduced to a maximum of 256..
-FTP Server: The NLST command now reports paths compliant with RFC 1123..
-When using the command line parameter --config-version-check ignore, the expected version is now written to the settings files if a mismatch is detected..
-nix: Logo icons are no longer embedded in the executables, they are instead installed to the proper system paths..
-nix: Added a filezilla-server-gui.desktop file, so that the Admin UI can easily be opened by desktop environments..
-Maximum number of log file rotations has been reduced to a more sensible amount and the rotation algorithm has been changed to be more efficient..
Download FileZilla Server v1.5.0-rc1
sugar
Global Moderator
Global Moderator
Post by sugar »
FileZilla Server v1.5.0 Released-(2022-07-20)
Admin UI: Connection dialog did not remember the last used port if there are multiple saved entries for the same hostname with different ports..
Download FileZilla Server v1.5.0 Released-
sugar
Global Moderator
Global Moderator
Post by sugar »
FileZilla Server v1.5.1 Released-(2022-07-29)
Fixed a crash if a session is closed and the data connection receives a connection error at the same time..
MSW: The notification area icon now displays again in all display scale factors..
Admin UI: Fixed switching from "Use system credentials to log in" to "Require a password to log in" not applying..
Download FileZilla Server v1.5.1
