Sky Germany Solution Ncam 13.1
Has thanked: 14324 times
Been thanked: 1623 times
The new version of Ncam 13.1
Sky Germany channels work without any problems and very fast on this version
Just put this code in your ncam.conf file
[streamrelay]
stream_ecm_delay = 5
stream_emm_enabled = 1
stream_relay_ctab = 098D
https://www.mediafire.com/file/ov2uk6r8j4iqdba/Ncam_3.1.zip/file
zapppa
Has thanked: 43 times
Been thanked: 86 times
Italy
Re: Sky Germany Solution Ncam 13.1
Post by zapppa »
Wow. I'll try
zapppa
Italy
Post by zapppa »
It works. Thanks.
Return to “Oscam”
