Meme Generator PRO v4.6255
Meme Generator PRO v4.6255 [Patched][Mod]
Overview: With Meme Generator you can create the funniest memes and share them with your friends through your favorite apps.
With Meme Generator you can create the funniest memes and share them with your fariends through your favorite apps.
Main features of Meme Generator:
βœ“ More than 1000 high quality meme templates with lots of hilarious example captions
βœ“ Custom meme support makes it possible to use any picture from your device
βœ“ Deep fry your memes and add other funny effects to memes
βœ“ Weekly community content updates
βœ“ Generate your own Breaking News memes
βœ“ Share memes through any app on your device or save them to your gallery
βœ“ Hundreds of included stickers with the possibility to create custom stickers
βœ“ Adjust text color and size freely
βœ“ More than 60 fonts to choose from
βœ“ Create complex modern or classic memes with multiple captions
βœ“ Combine multiple saved memes into one multi panel meme
βœ“ Ability to crop images to fit different formats
βœ“ Add borders around any picture
βœ“ Favorite memes feature allows you to create your own list of favorite memes
βœ“ No watermarks are added to memes
βœ“ Your privacy is our top priority – Meme Generator does NOT automatically upload any meme you create or import
βœ“ Create any type of dank meme format, even immensely popular Deep Fried effect memes
DISCLAIMER: Pictures and captions in this app do not reflect the opinions of the ZomboDroid Team. All memes and examples are user submitted!
v4.6255
- New memes added:
βœ“ King Charles Sausage Fingers
βœ“ It's Time For You To Look Inward
βœ“ Carmy In The Kitchen
βœ“ Ye Says Nay
MOD INFO
Modded Google play/LP not needed
Security check removed
Unwanted files/Folders removed
Optimized graphics/ zipalighned
Remove default .source name of java files;
Debug Info Removed
By Srajawwal09 with special thanks to ill420smoker bro
This app has NO advertisements
http://ul.to/x199md8f
Return to β€œMobile Zone”
