multics r84 brutus-z fix
Multics config Download & Config Profiles
admin
SF FOUNDER
SF FOUNDER
Has thanked: 1662 times
Been thanked: 422 times
Post by admin »
this is the best version of multics r84 brutus-z with fix for all profiles/ NO LIMITATION OF USERS - PEERS - SERVERS.....
100% stable
DEFAULT DEFAULT KEY          : 01 02 03 04 05 06 07 08 09 10 11 12 13 14
DEFAULT ECM CHECK            : NO
DEFAULT ECM CHECK LENGTH     : NO
DEFAULT DCW TIMEOUT          : 5700
DEFAULT DCW RETRY            : 0
DEFAULT DCW CHECK            : NO
DEFAULT DCW HALFNULLED       : NO
DEFAULT DCW SWAP             : NO
DEFAULT DCW MAXFAILED        : 10
DEFAULT SERVER MAX           : 0
DEFAULT SERVER INTERVAL      : 100
DEFAULT SERVER TIMEOUT       : 5700
DEFAULT SERVER TIMEPERECM    : 0
DEFAULT SERVER VALIDECMTIME  : 5000
DEFAULT SERVER FIRST         : 5
DEFAULT ACCEPT NULL CAID     : NO
DEFAULT ACCEPT NULL PROVIDER : YES
DEFAULT ACCEPT NULL SID      : NO
DEFAULT ENABLE CCCAM         : YES
DEFAULT ENABLE NEWCAMD       : YES
DEFAULT ENABLE RADEGAST      : NO
DEFAULT ENABLE CAMD35        : NO
DEFAULT ENABLE CS378X        : NO
DEFAULT ENABLE SKIPCWC         : YES
DEFAULT ENABLE CACHE         : YES
DEFAULT ENABLE CACHEEX       : NO
DEFAULT CACHEEX MAXHOP       : 2
DEFAULT CACHEEX VALIDECMTIME : 5700
DEFAULT RETRY NEWCAMD        : 0
DEFAULT RETRY CCCAM          : 0
DEFAULT CACHE TIMEOUT        : 800
DEFAULT CACHE SENDREQ        : YES
DEFAULT CACHE RESENDREQ      : NO
DEFAULT CACHE SENDREP        : YES
DEFAULT CACHE STATIC         : NO
[ skyde austria 09C4 ]
PORT                         : 19000
CAID                         : 09C4
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ TNTSAT - 0500 ]
PORT                         : +
CAID                         : 0500
PROVIDERS                    : 30b00
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ MOVISTAR222 - 1810 ]
PORT                         : +
CAID                         : 1810
PROVIDERS                    : 0, 4001, 4101
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ MEO Portugal-1814 ]
PORT                         : +
CAID                         : 1814
PROVIDERS                    : 0, 5211, 5221, 25211, 1, 2, 3, 4, 5, 6, 7, 8, 9
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ ZON CABO-RCS DIGI 1802 ]
PORT                         : +
CAID                         : 1802
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ HD+ -1830 ]
PORT                         : +
CAID                         : 1830
PROVIDERS                    : 0, 3411, 8011
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ POLSAT CYFROWY - 1803 ]
PORT                         : +
CAID                         : 1803
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ POLSAT CYFROWY-1861 ]
PORT                         : +
CAID                         : 1861
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ SAT BG - 0B01 ]
PORT                         : +
CAID                         : 0B01
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ Yes Amos-090D ]
PORT                         : +
CAID                         : 090D
PROVIDERS                    : ffffff, 0, 1, 2
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ DishTV CONEX-0B00 ]
PORT                         : +
CAID                         : 0B00
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ AirTel-108 ]
PORT                         : +
CAID                         : 09AA
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ NC+ CYFRA - 0100 ]
PORT                         : +
CAID                         : 0100
PROVIDERS                    : 65, 68
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ MEDIASAT PREMIUM-1805 ]
PORT                         : +
CAID                         : 1805
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ TIVUSAT/RAI - 183D ]
PORT                         : +
CAID                         : 183D
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ BulSatCom - 4AEE ]
PORT                         : +
CAID                         : 4AEE
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ MOVISTAR - 0100 ]
PORT                         : +
CAID                         : 0100
PROVIDERS                    : 4106
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ SKY LINK - 0D96 ]
PORT                         : +
CAID                         : 0D96
PROVIDERS                    : 4, 8, c, 10, 48
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ X Club -0500 ]
PORT                         : +
CAID                         : 0500
PROVIDERS                    : 24400, 25100, 32000, 32500, 32010, 41700, 41900, 41710, 42200, 42210, 43800, 51e00, 50f00
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ TIVUSAT/RAI - 183E ]
PORT                         : +
CAID                         : 183E
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ NC+ 4k - 1884 ]
PORT                         : +
CAID                         : 1884
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ ORF-0648 ]
PORT                         : +
CAID                         : 0648
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ ORF ICE 19.2- 0D98 ]
PORT                         : +
CAID                         : 0D98
PROVIDERS                    : 4
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ Canal Digitaal NL-0100 ]
PORT                         : +
CAID                         : 0100
PROVIDERS                    : 6a
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ HD+ -1843 ]
PORT                         : +
CAID                         : 1843
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ ORF DIGITAL - 0D95 ]
PORT                         : +
CAID                         : 0D95
PROVIDERS                    : 4, 10
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ SKY LINK - 0624 ]
PORT                         : +
CAID                         : 0624
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ TOTAL TV Serbia - 091F ]
PORT                         : +
CAID                         : 091F
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ SFR-FR-0500 ]
PORT                         : +
CAID                         : 0500
PROVIDERS                    : 23800, 40810, 40820, 50800, 50810, 60200, 60210
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ ART - 0604 ]
PORT                         : +
CAID                         : 0604
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ Canal Digitaal-0100 ]
PORT                         : +
CAID                         : 0100
PROVIDERS                    : 6c
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ UPC/FOCUSE/ESS-0B02 ]
PORT                         : +
CAID                         : 0B02
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ RCS/RDS/DIGI TV - 1880 ]
PORT                         : +
CAID                         : 1880
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ SKY DIGITAL UK - 0963 ]
PORT                         : +
CAID                         : 0963
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ UPC 0D97 ]
PORT                         : +
CAID                         : 0D97
PROVIDERS                    : 4
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ D-Smart - 092B ]
PORT                         : +
CAID                         : 092B
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ TELESAT - 0100 ]
PORT                         : +
CAID                         : 0100
PROVIDERS                    : 6d
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ BIS TV - 0500 ]
PORT                         : +
CAID                         : 0500
PROVIDERS                    : 42300, 42800, 42820
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ TELESAT-1819 ]
PORT                         : +
CAID                         : 1819
PROVIDERS                    : 0, 6d
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ ORF 19.2- 0650 ]
PORT                         : +
CAID                         : 0650
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ OSN-1708 ]
PORT                         : +
CAID                         : 1708
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ Csat1811 ]
PORT                         : +
CAID                         : 1811
PROVIDERS                    : 0, 3311, 3315
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ MEDIASAT PREM - 1804 ]
PORT                         : +
CAID                         : 1804
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ KONTINENT TV 85.0E ]
PORT                         : +
CAID                         : 0602
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ UPC 1815 ]
PORT                         : +
CAID                         : 1815
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ TV Vlaanderen-1817 ]
PORT                         : +
CAID                         : 1817
PROVIDERS                    : 6a
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ MEO PORTUGAL-0100 ]
PORT                         : +
CAID                         : 0100
PROVIDERS                    : 5211, 5221, 5225
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
[ UPC HU 16-W- 0653 ]
PORT                         : +
CAID                         : 0653
PROVIDERS                    : 0
ECM CHECK                    : NO
DCW HALFNULLED               : NO
DCW SWAP                     : NO
r84-z.zip
(366.54 KiB) Downloaded 852 times
Return to “Multics Download & Config”
