G-Stomper Studio v5.8.6.5
G-Stomper Studio v5.8.6.5 [Paid]
Overview: Full-featured, High-Quality Groovebox Workstation, perfect for Live Performance!. G-Stomper Studio is a Music Production Tool, highly optimized for doing Electronic Live Performances in Studio Quality. The integrated VA-Beast is a polyphonic virtual analog Synthesizer to produce complex synthetic sounds of any variety, designed for experienced sound designers as well as for beginners.
G-Stomper Studio is a Music Production Tool, highly optimized for doing Electronic Live Performances in Studio Quality. It's a feature packed, Step Sequencer based Drum Machine/Groovebox, a Sampler, a Virtual Analog Performance Synthesizer (VA-Beast), a polyphonic + a monophonic Step Sequencer for melodies, a Track Grid Sequencer for Beats, a Piano Keyboard, 24 Drum Pads, an Effect Rack, a Master Section, a Line Mixer and a Live Pattern/Song Arranger. Wherever you are, take your mobile device and start straight away creating your own music.
The integrated VA-Beast is a polyphonic virtual analog Synthesizer to produce complex synthetic sounds of any variety, designed for experienced sound designers as well as for beginners. So it's up to you if you just explore the Factory sounds or if you start right away with designing your own sounds in impressive studio quality. Its sound capabilities paired with the intuitive and clearly laid out interface simply makes G-Stomper VA-Beast to the ultimate Mobile Synthesizer. You will be able to create the sounds you want, and you'll do it faster than on any other mobile synthesizer.
Instruments and Pattern Sequencer
• Drum Machine : Sample based Drum Machine, max 24 Tracks
• Sampler Track Grid : Grid based Multi Track Step Sequencer, max 24 Tracks
• Sampler Note Grid : Monophonic Melodic Step Sequencer, max 24 Tracks
• Sampler Drum Pads : 24 Drum Pads for live playing
• VA-Beast Synthesizer : Polyphonic Virtual Analog Performance Synthesizer (Advanced FM support, Waveform and Multi-Sample based Synthesis)
• VA-Beast Poly Grid : Polyphonic Step Sequencer, max 12 Tracks
• Piano Keyboard : On various Screens (8 Octaves switchable)
• Timing & Measure : Tempo, Swing Quantization, Time Signature, Measure
Mixer
• Line Mixer : Mixer with up to 36 Channels (Parametric 3-band Equalizer + Insert Effects per Channel)
• Effect Rack : 3 chainable Effect Units
• Master Section : 2 Sum Effect Units
Arranger
• Pattern Set : Live Pattern/Song Arranger with 64 concurrent Patterns
Audio Editor
• Audio Editor : Graphical Sample Editor/Recorder
Feature Highlights
• Ableton Link: Play in sync with any Link-enabled app and/or Ableton Live
• Full round-trip MIDI integration (IN/OUT), Android 5+: USB (host), Android 6+: USB (host+peripheral) + Bluetooth (host)
• High Quality Audio Engine (32bit float DSP algorithms)
• 47 Effect Types including Dynamic Processors, Resonant Filters, Distortions, Delays, Reverbs, Vocoders, and more
+ Side Chain Support, Tempo sync, LFOs, Envelope Followers
• Per Track/Voice Multi-Filters
• Real-Time Sample Modulation
• User Sample Support: Uncompressed WAV or AIFF up to 64bit
• Tablet optimized, Portrait Mode for 5 inch and bigger screens
• Full Motion Sequencing/Automation Support
• Import MIDI files/songs as Pattern Set including Song arrangement
Full Version only
• Support for additional Content-Packs
• WAV File Export, 8..32bit up to 96kHz: Sum or Track by Track Export for later use in the Digital Audio Workstation of your choice
• Real-Time Audio Recording of your Live Sessions, 8..32bit up to 96kHz
• Export Patterns as MIDI for later use in your favorite DAW or MIDI Sequencer
• Share your exported Music
Minimum recommended device specs:
1000 MHz dual-core cpu
800 * 480 screen resolution
Headphones or speakers
Check out the free demo before buying the full version
Permissions
Storage read/write: load/save
Bluetooth+Location: MIDI over BLE
Record Audio: Sample Recorder
★ Untouched Paid apk with Original Hash Signature
★ Certificate MD5 digest: 24f45f974e7c85cf3d5ea205abad39ae
★ No changes were applied
➡ Languages: Full Multi Languages
➡ CPU architectures: arm64-v8a, armeabi-v7a, x86, x86_64
➡ Screen DPIs: 120dpi, 160dpi, 240dpi, 320dpi, 480dpi, 640dpi
Fully prepared the app for Android 13
Removed the "Allow to navigate out of user folders" setting on Android 8 and higher, as no other folders can be accessed anyway on later OS versions
Updated to the latest Ableton Link libraries
Updated to the latest NDK25b
http://ul.to/vd1sghzr
