Edision Os Mio+ 4K Specs
- admin
- SF FOUNDER
- Has thanked: 1664 times
- Been thanked: 405 times
- Type: 4K UHD E2 Linux Combo Reivever DVB-S2X + DVB-S/T2/C with Multi Stream Support
- 1 x Tuner DVB-S2X
- 1 x Tuner DVB-S2/T2/C
- Decoding: H.265/HEVC 10bit decoding support (covered by patents listed at patentlist.hevcadvance.com)
- Multi Stream T2MI & Blind Scan support
- Linux operational system
- Processor: Dual Core ARM 1.5 GHz
- FLASH 8GB eMMC/RAM 2GB DDR4 2400Mhz
- OLED Display
- 4K UHD Multimedia Player
- Web Browser & HbbTV support
- Free Internet Streaming TV and Radio
- Dual Band 2x2 Wi-Fi 802.11ac 5G/2.4G with MU-MIMO
- 2 x Pluggable Wi-Fi Antennas
- Bluetooth: embedded 2.1/3.0/4.0
- Unlimited channel memory
- Hyper-sensitive tyner for receiving even the weak-signal channels
- 1 x Smartcard reader
- 10/100 Mbps Ethernet interface
- 2 x USB2.0 ports
- 1 x HDMI 2.0a Connection
- 1 x jack to RS232
- 1 x jack to IR
- 1 x S/PDIF
- Channel switch in less than 1 second.
- Extensive ΕPG and programmed viewing via EPG
- Expandable Add-Ons & Plug-Ins
- Supports Bouquet list
- Multilingual OSD, Skin - support
- Channel search: Fully automatic/Manual
- Time Shift function and Multi Timers
- Supports Teletext & and OSD and VBI subtitles
- Compatible with DiSEqC 1.0, 1,1 ,1.2 and 1.3 (USALS)
- Supports SCR / CSS (EN50494 & EN50607)
- Power consumption less than 0.5 Watt, in low-power stand-by mode
Front Panel:
- Display: OLED
- Display Buttons: Power, Channel -/+
Back Panel:
- Input Sat-IF: 1x F-type
- Input RF: 1x IEC-type
- Connection TV: 1x HDMI
- Video output: 1x HDMI
- Audio output: Standard optical (S/PDIF)
- 2 x WiFi Antennas
- 1 x Smartcard slot
- 1 x Ethernet plug
- 1 x jack to RS232
- 1 x jack to IR
- 1 x DC in (for the external PSU)
Package contains:
- Universal Remote Control 2in1
- External PSU 12v
- Jack to IR cable
- USB extension cable
- 2 x Wi-Fi Antennas
- 2 x "ΑΑΑ" batteries
- Start Guide EN/DE/GR
General:
- Case: Aluminum
- Dimensions: (W x H x D): 180x40x140 (mm)
- Weight: 0,7 kg
- Color: Grey
- Warranty: 2 years
Always Press THANKS button
- kamacnik1
- Active Member
- Has thanked: 4 times
- Been thanked: 8 times
Re: Edision Os Mio+ 4K Specs
I own this receiver more than a year now, and I am very pleased with it, no problem what so ever
Everything work as it should, sensitive tuners, both S2x and T2, hardware multiboot for 4 images, excellent dual wifi, good remote control etc etc
Official Support from Pure2 , Openpli , Openatv ,OpeBH , Openvix , Openspa, Openvision, Opendroid ..., more than enough images
Small by dimensions, but powerfull in work, my recomendation
- admin
- SF FOUNDER
Thanks for the Feedbackkamacnik1 wrote: ↑18 Apr 2022, 02:15 I own this receiver more than a year now, and I am very pleased with it, no problem what so ever
