[OE 2.6] Peter Pan Neverland DreamONE Ultra HD
General discussions, images, information, tutorials, picons, skins, plugins, settings, software and tools for receivers
Been thanked: 1668 times
So what's new in this upgrade:
1. We have now added to the Service Search so you will be asked if you want to Zap Back to last playing service.
- Just be aware if you are using an Motor Dish it can start moving when you Zap back after a full scan.
- But this should fix the Manual Scan problem where you have to leave the scan screen and go back for a new single scan. (Thnx to Dreamy for the code)
2. Upgrade of the PP Menu System (BlueButton)
- Removed AutoMount Manager since it's not supported by OE 2.6.
- All Network Mounts is to be made from the regular MountManager
3. Update the PP Remotecontrol settings plugin
- Fix the broken settings for the RC - 20BT Remote so it also works with 3rd-party plugins (QuickButton plugins)
4. Removed the PP LCD Setup plugin. Only the Two have LCD and until the Seven arrives there is no need for this plugin.
5. Add Italian translation for PP menus. thanks to @Spaeleus
6. Some background tweaks to do some Image housekeeping
Regards Team Peter Pan...
https://www.mediafire.com/file/t5vr20ps ... ar.xz/file
Return to “Dreambox”
