Stalker Portal Player 7.2
Has thanked: 14339 times
Been thanked: 1649 times
It is the best IPTV portal player, which allows you to watch the best channels in the world. This player is developed from the Serbian team and is 100% compatible with them because it is updated every time
This update we have incorporated new servers and the bugs of the old version have been corrected
Characteristics
The size of the program is very small at 19MB and it does not take up much hard disk space.
The interface of the program is very simple and the simple user can recognize it.
The portable version of the Stalker player does not require installation.
You can add so many iptv servers in the iptv stalker program.
There are thousands of codes for the program that are widely available, making it one of the best must-have apps.
A server includes a large number of King Idris that can switch between them, and each of them includes six IPTV M3Us that differ from each other.
You can watch thousands of open and encrypted channels streamed live on your computer.
Watching the programs of the Bn Sport channels live.
There is no hacking in the application and it works at weak internet speeds because it does not consume much internet, plus the servers contain many SD channels.
Available for computers and Android devices.
The stalker gamer program is free and requires no expense.
https://mega.nz/file/bW4GkTqI#-wcREnJM4k5ZUzO1HousJbn7me-dYAM15j9P9IEMAoU
Aliwa22
Tunisia
Re: Stalker Portal Player 7.2
Post by Aliwa22 »
i cant download it pls help thanks
Aliwa22 wrote: ↑12 May 2024, 22:03 i cant download it pls help thanks
Error show please
hasmevask
Been thanked: 5 times
India
Post by hasmevask »
Please reupload and share new url , the above link, deleted from mega
Stalker Portal Player For PC V7.1 By Sahbaz
What's new?
* Fixed Access violation bug on some panels
* Added keyboard shortcuts and mouse events
* Added a button to hide/show the channel settings panel to make more room for the channel list
* Added a help button to see keyboard shortcuts and mouse events
* Added channel FPS information
* Added mute button
* Added auto-reconnect feature when channel disconnects or freezes
* Added more aspect ratio options
* No need to install VLC player anymore. All necessary files are included in the folder
Keyboard shortcuts:
Esc - Exit Full Screen
M - Mute (Only Works in Full Screen)
Right Arrow - Next Channel (Only Works in Full Screen)
Left Arrow - Previous Channel (Only Works in Full Screen)
Mouse Events:
Left Click Double Tap - Full Screen/Normal Screen
Middle Button Slide Up - Volume Up (Only Works in Full Screen)
Middle Button Slide Down - Volume Down (Only Works in Full Screen)
Hi Friends. Stalker Portal Player v7.1 is ready to download.
What's new?
* Fixed Access violation Error in some panels
* Added a button to hide/show channel settings panel to make more room for the channel list
* Added audio mute button
* Added auto-reconnect feature when channel connection goes down or freezes
* No need to install VLC player anymore. All the necessary files are included in the folder
Keyboard shortcuts:
M - Mute (Works Only in Full Screen)
Right Arrow - Next Channel (Works Only in Full Screen)
Left Arrow - Previous Channel (Works Only in Full Screen) )
Mouse Events:
Left Button Double Click - Enter/Exit Full Screen
Middle Button Scroll Up - Increase Volume (Works Only in Full Screen)
Middle Button Scroll Down - Decrease Volume (Works Only in Full Screen)
If you have trouble downloading, use another browser
virustotal: https://www.virustotal.com/gui/file...a ... /detection
Download Link: https://s2.dosya.tc/server23/91fpp1/sta ... 1.rar.html
Alternative Download Link: https ://dosya.co/cab37m09n2y7/stalker_portal_player_v7.1.rar.html
hasmevask
India
Post by hasmevask »
Stalker Portal Player 7.2 Needed ,Kindly share
Thanks for share 7.1 too
hasmevask wrote: ↑25 May 2024, 13:02 Stalker Portal Player 7.2 Needed ,Kindly share
use this one same same
https://sat-forum.net/viewtopic.php?f=4 ... 593#p64593
hasmevask
India
Post by hasmevask »
The Founder wrote: ↑25 May 2024, 13:04
Thanks it's ooks same 7.1 but need other one
