Niagara Launcher ‧ fresh/clean v1.7.4 [Pro] [Fixed]
Been thanked: 1027 times
Overview: Niagara Launcher is a fresh homescreen that has a clean and minimalistic ui. Due to its unique design you can open apps more quickly and use your phone with just one hand. You also get to experience the latest and greatest features of Android 10, including smart replies and dark mode.
Niagara Launcher gives your phone a whole new look and offers a minimalistic experience to help you to form a healthy relationship with your phone. You also get to experience the latest and greatest features of Android 10, including smart replies and dark mode.
Top reasons to use Niagara Launcher:
All apps in a simplified list · You just need to scroll either of the edges on the launcher to get access to all of your apps instantly.
Interact with notifications right on the home screen · Unlike most other launchers, Niagara Launcher gives you essential information about received messages at a glance and directly on your home screen. Swiping on a notification expands it and lets you reply quickly.
Ergonomic efficiency · Niagara Launcher is optimized for one hand usage. Your apps are always within reach and the scrollbar can be used from both sides.
Lightweight & fast · Niagara Launcher is not only lightweight to your phone’s resources, but at just a few megabytes in size, the app takes up very little space. Next to simplicity, fluidity is one of the most important aspects of Niagara Launcher.
Media Player · Music controls automatically show up on your home screen when they're needed, too – anytime you're playing audio from an app.
Theming · Niagara Launcher pulls colors from your wallpaper for a nice thematic effect. Additionally, you can choose between a light or dark theme. Icon packs are supported as well – you can even apply an icon of your choice to each app individually.
Hide unwanted Apps · Hide all pre-installed bloatware, to get a clean and tidy home screen.
❏ Mod info :
๏ Premium Features Unlocked Except Weather (Use Any Weather Widget App)
๏ Random Numbers Fixed
๏ Cleaned
❏ Note : If You Face Any Problem Click On Niagara > App Info > Storage > Clear DataIf You Face Any Problem Click On Niagara > App Info > Storage > Clear Data.
Use Any Weather Widget App & If You Are Using My Old Mod Just Install it Overwrite. No Need To Uninstall The Current.
➤ Modded by Taz
Bugfix: Checking notifications that contain large images could lead to a crash in v1.7.3.
http://ul.to/lnpjjn9c
