How to find Biss Key of your fav channels - Method
- Has thanked: 14359 times
- Been thanked: 1668 times
HOW TO FIND A BISS CW keys using CW Finder ("CWBruteList") and "CW_Attack_list" ("CW_Brute_list")
Only for who have PC with OP Windows 64-b.i.t
- download application "CWBruteList" (only 64-b.i.t version) on Desktop
- create folder for captured .ts files (example on D:/Recorded .ts files)
- in the same folder (D:/Recorded .ts files) download and copy "CW_Brute_list" .txt file
Find an active satellite channel or feed (working in BISS encryption).
Record a full .ts file (size of 50-170 MB) directly or indirectly (copying) in a created folder on a PC,
using a PC satellite DVB card (with DVBDream, ProgDVB or similar applications) or using a satellite DVB receiver.
Now run "CWBruteList" application.
A. Choose the path to the folder (D:/Recorded .ts files) and select recorded .ts file
i
B. Select "CW_Brute_list" .txt file
C. Click on button "Proc.Program"
D. Confirm on button "OK"
E. The Result in 1 second
NOTE: BISS CW key will be found with "CWBruteList" only if the .ts file is correct and if the BISS CW key exists in the "CW_Brute_list" file !
The latest "CW_Brute_list'' is by shishmish
Update 2018
Thanks shishmish
i
Update 2018
Thanks shishmish
- Mavrick2020
- Has thanked: 10 times
- Been thanked: 62 times
Re: How to find Biss Key of your fav channels - Method
does this still work if i record a biss feed using my octagon sf8008 and download it from the hdd and add to this software?
Yes working it still mateMavrick2020 wrote: ↑01 May 2024, 14:37 does this still work if i record a biss feed using my octagon sf8008 and download it from the hdd and add to this software?
- Mavrick2020
even if i do it the way i said?The Founder wrote: ↑01 May 2024, 17:44Yes working it still mateMavrick2020 wrote: ↑01 May 2024, 14:37 does this still work if i record a biss feed using my octagon sf8008 and download it from the hdd and add to this software?
so record about 1 or 2 mins of biss encrypted feed on my octagon sf8008, and then download it from the harddrive to my pc and add to the tool?
- Mavrick2020
- Mavrick2020
It's working now software??
- YSN
- Super member
- Has thanked: 2 times
- Been thanked: 11 times
LÜTFEN RİCA EDİYORUM BANA ŞU PROGRAMI TÜRKÇE BİLEN VEYA TÜRKÇE ALTYAZI OLARAK VİDEO ÇEKİP GÖNDEREBİLİR Mİ
- Mavrick2020
HI ME AGAIN, ANYONE USING CSA RAINBOW TABLES V2?
Users browsing this forum: No registered users and 16 guests
