MX Player v1.48.12 [Final]
MX Player v1.48.12 [Final] [Unlocked] [AC3/DTS] [No Google]
Overview: Powerful video player with advanced hardware acceleration and subtitle support.
Whats New:
- We optimize forget PIN flow for Private folder
- You can now manually select external subtitles on the local network shares
- We have further optimized the navigation drawer and playback menu to provide a better experience.
- This update also fixes the issues in handling of external Web URLs on Android 12 devices.
For OTT Users:
- PIP mode now supports Android System PIP.
★★★ MOD ★★★
★ Removed ad code.
★ Removed all google code, except for the one needed for chromecast support, stat-anal, evaluation window, update suggestion window.
★ Removed main trackers.
★ Personal folder and file sharing are left unchanged.
★ Languages EN, RU, UK.
★ Google services not required
★ It works on Android 12
MX Player Custom Codec [AC3,DTS,MLP,TRUEHD, etc..] instructions:
Go to the Local Player Settings/Decoder/General
and tap the Custom Codec tab then select the MX Player Custom Codec zip file.
http://ul.to/3kkjkeb3
newfel
Has thanked: 10 times
Been thanked: 8 times
Re: MX Player v1.48.12 [Final]
Post by newfel »
Teşekkür ederim
