FootOnsat Plugin
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
FootOnsat Plugin
Post by sugar »
enigma2-plugin-extensions-footonsat_1.6_all
- Add new tournaments
- Modify converters to be compatible with py3
- Add the ability to change the order of the tournaments or hide them
- Possibility to move with the UP/DOWN/LEFT/RIGHT button
- HD skin support has stopped
https://www.mediafire.com/file/lorcccr1 ... b.rar/file
https://www.mediafire.com/file/vqfa7wk1 ... k.rar/file
mojoxx
Has thanked: 3 times
Been thanked: 8 times
Re: FootOnsat Plugin
Post by mojoxx »
What does this plugin do?can we watch the matches with it?
Has thanked: 14281 times
Been thanked: 1572 times
mojoxx wrote: 13 Apr 2022, 00:41 What does this plugin do?can we watch the matches with it?
Yes easily install and enjoy
sugar
Global Moderator
Global Moderator
Post by sugar »
FootOnsat Plugin developed By ziko & redouane
To install the plugin:
wget -q "--no-check-certificate" http://raw.githubusercontent.com/ziko-ZR1/FootOnsat/main/Download/install.sh -O - | /bin/sh
enigma2-plugin-extensions-footonsat_1.7-r1_all
enigma2-plugin-extensions-footonsat_1.7-r1_all.ipk (4.50MB)
