Gx 6605s help urgent
aa7590
Been thanked: 6 times
Post by aa7590 »
as salam all memebers gx 6605s ki cutomer id remote controll ka kon sa number press karna par show hoti ha
Has thanked: 14329 times
Been thanked: 1640 times
Re: Gx 6605s help urgent
aa7590 wrote: ↑14 Aug 2022, 18:58 as salam all memebers gx 6605s ki cutomer id remote controll ka kon sa number press karna par show hoti ha
GX6605S HW 203 INVALID FILE OR OCCURED ERROR FIX WITH HEXWORKSHOP
HOW TO CHANGE GX6605S HW:203.00.001 TO OTHER HARDWARE
STEP 1:GX6605S SOFTWARE OPEN WITH HEX WORKSHOP
STEP 2:GOTO TO EDIT AND THEN CLICK ON GOTO
STEP 3:NOW WRITE OFFSET ADDRESS 1F00E AND CLICK ON GO
STEP 4:CHANGE HERE YOUR OWN RECEIVER HARDWARE AND THE PRESS SAVE BUTTON
aa7590
Post by aa7590 »
Shahid Geo wrote: ↑14 Aug 2022, 22:51
thank youi brothe for help
ek problem aur ha hellobox wala firmware kiyya ha box par par remote work nahi karta HA HOW TO FIX HEL URGENT
aa7590 wrote: ↑16 Aug 2022, 08:53
rs232 to upgrade with original sw
razka
Global Moderator
Global Moderator
Been thanked: 174 times
Azerbaijan
Post by razka »
After updating the firmware, the remote control will probably not work, how to make the remote control work you need to point the remote control at the receiver and press any buttons on the remote control until the remote control image appears
then repeat everything that will be shown on the TV screen or use the universal remote control
Return to “Others STB”
