TikTok v25.3.4
Been thanked: 1028 times
TikTok v25.3.4
TikTok v25.3.4 (Unlocked)(InBuilt Region Changer)(Plugin v2.4.9)
Requirements: 4.4+
Overview: TikTok is THE destination for mobile videos. On TikTok, short-form videos are exciting, spontaneous, and genuine. Whether you’re a sports fanatic, a pet enthusiast, or just looking for a laugh, there’s something for everyone on TikTok.
All you have to do is watch, engage with what you like, skip what you don’t, and you’ll find an endless stream of short videos that feel personalized just for you. From your morning coffee to your afternoon errands, TikTok has the videos that are guaranteed to make your day.
★ Mods-
- Removed inVideo Google & Other ads
- Made video and GIF downloading without watermark to Movies/TikTok folder instead of DCIM/Camera
- Removed all restrictions on downloads, you can download any video
- Removed many other restrictions
- The application was cleaned as much as possible
- Maximum compression + ZipAlign
- Disabled unnecessary activities
- Removed restrictions on duets, stitching and dynamic wallpapers
- Rewind is now available in any video
- Battery drain optimization
- Removed regional restrictions
- Fixed Facebook authorization
- Fixed VK authorization
- Fixed Google authorization
- Disabled autostart
- Enabled High Quality Audio
- Enabled High Quality Video
- Enabled Ultra Resolution
- Enabled Anti Aliasing
- Hidden root rights
- Disabled InAppBillingService
- Disabled all types of Analytics
- Disabled Measurement
- Enabled watch history
- Added author tag for the name of the downloaded file
★ Exclusively Modded By DMITRY Nechoporenko
★ Plugin For TikTok Features-
- Details for regions (Long press on Region option)
- Option for matching post's region with selected region. (Don't show post's that are not related to selected region)
- Option for hide ads from trending list in discover section
- Option for disable playing videos in loop behavior
- Option for hide live streams from timeline
- Option for hide post captions from everywhere
- Option for hide long posts (with custom length) from timeline
-Ability to change download directory
- Ability to make keyword blocklist for captions (Post's with specific words will not appear in timeline)
- Remove Video watermark & GIF watermark options
- Ability to bypass duet & stitch privacy settings
- Theme switcher for plugin
- Added new speeds in playback speed option. (1.25x, 1.5x, 2.25x, 2.5x)
- Option for downloading videos without sound (Mute videos will save with mute.mp4 prefix)
- Option for changing font style (Currently support 6 new font + default)
- Option for changing ui colors like main bottom background color
- Added ability to reset plugin settings (Menu > Reset)
- Tap app bar for navigating to top of the options list
- Long press on options to see more info
★ v2.4.9 Changelog-
- Synchronized translations with Crowdin
★ Exclusively Developed Till v2.2.0 By SAEEDStarv
★ Exclusively Redeveloped Further By DMITRY Nechoporenko
★ Note1- If TikTok is Banned in Your Country. Then Launch Plugin & Select Any Allowed Region Eg-USA & launch Tiktok. If its Shows Unlimited Loading Time then Connect to USA VPN first & Relaunch with Plugin..
★ Note2- If you face "Too Many Attempts" Error on login, Use Forgot Password Option.
Get our latest and greatest effects.
This app has credit advertisements
http://ul.to/bkvb4j7s
