Help on config for sat @ 45E
yuviDX
Has thanked: 1 time
Been thanked: 4 times
Sri Lanka
Post by yuviDX »
Dear all,
I have created a multics cs server but currently is not decrypting the ecm for dialog tv @45E. Can anyone able to help to fix this? it will be a great help and i will provide free servers to the community if it worked for 1 year for sure.
[13:45:28.974] <- ecm from CCcam client 'user' ch 0631:000000:007a:32022ffa
[13:45:28.978] |> decode failed to CCcam client 'user' ch 0631:000000:007a (4ms)
[13:45:29.454] <- ecm from CCcam client 'user' ch 0631:000000:007a:01499b47
[13:45:29.458] |> decode failed to CCcam client 'user' ch 0631:000000:007a (4ms)
if anyone want to check my server for what i am missing sent me a pm for login details, thanks.
Has thanked: 14335 times
Been thanked: 1642 times
Re: Help on config for sat @ 45E
you have reshare line or local card?? in multics also tell me multics version
yuviDX
Has thanked: 1 time
Sri Lanka
Post by yuviDX »
reshare line, i have two server running different version but in both same error.
server 1 - Version: MultiCS r82-HB59-alheira.org
server 2 - Version: MultiCS r84-HB58-alheira.org
yuviDX wrote: ↑30 Jul 2022, 13:06 reshare line, i have two server running different version but in both same error.
use r69 or r70 with right profile 45E
:tfds
Return to “Talk-Shawk”
