IPTV Extreme v117.0 [Firestick/AndroidTV/Mobile] [Official] [Licensed]
Been thanked: 1028 times
Overview: Watch IPTV from your service provider or free playlists found across the Web
*** PLEASE NOTE THIS APP DOES NOT CONTAIN ANY CHANNLES ***
*** THE APPLICATION REQUIRES A PLAYLIST TO WORK ***
If you usually use VLC or IPTV bouquet for Dreambox to watch TV this app is for you.
You need to use your own IPTV list to watch channels
I suggest to install VLC for Android or Better MX Player if the default Video Player is not able to Play streaming video
Features:
- Integrated Player (Advanced & Light)
- Chromecast Support (Beta)
- Parental Control
- Remote Controller support
- Backup / Restore Settings
- M3U playlists support
- Multi EPG support (TV Guide)
- Auto EPG update
- EPG alias management
- All the EPG providers are included
- Picons support in different size
- Ability to download On Demand Programs!
- Ability to record Live Streaming with time limit!
- More than 10 Themes availables!
- Time Recording
- Timers Management
- Autostart On Boot Function
- Set Memo function for Events on TV Guide
- Search for Similar Events on TV Guide
- Sliding EPG time
Additional features are available in Pro version:
- Ad free
- A big thanks from me
Setup instructions:
* First you'll need to add a Playlist by inserting m3u link or select a previously saved playlist file.
VERSION 117.0
-Bug Fix
Tested With Clean Install On A11Box, OnnBox, Gen2FS, Gen3FS, SmartFireTV, SmartAndroidTV, 3 Older Boxes, 6,7,8,9 & 10 Phones
No Mouse Toggle Needed
http://ul.to/c9igyai2
