Televizo - IPTV player v1.9.3.21 [Final] [Pro] [Mod]
Overview: Televizo is one of the easiest and feature packed Android IPTV apps on the market. Watch your favourite movies, cartoons, TV shows and programs from your provider on your Android phone, tablet, TV or TV-box.
Available features:
- Live broadcasts and history (archives, if playlist supports this function);
- You can add an unlimited number of M3U playlists;
- You can add an unlimited number of XML EPGs;
- Support for different streams (HLS, UDP and others);
- Pause and rewind are working correctly (if history is available), time-shift is supported;
- You can view, pause and rewind the broadcast, which is currently on the air (if history is available);
- When you open the application, the broadcast will continue from the moment when the application was closed (if history is available);
- On incoming calls/messages, the broadcast will stop and automatically continue after the end of the conversation;
- And much more...
The application is only a player and DOES NOT CONTAIN any preset channels.
To view, you need to add a playlist of your provider.
Have a nice watching!
Cleaned of trash.
Blocked ads and analytics.
Full screen preview unlocked.
Languages: en, be, de, es, fr, it, pl, pt, ru, tr, uk
Added:
- Support for Android 12;
- Support for large playlists;
- Separated categories for Xtream Codes playlists;
- Screen lock on phones and tablets;
- Remove videos from recently watched;
- Device will be able to go to sleep if the video is not playing;
- Clock will sometimes move a few pixels (relevant for OLED TVs);
- Turning on the previous video in the archive using rewind;
- Support for "tvg-shift" in playlist:
- Estonian language;
- Many other fixes and improvements.
http://ul.to/1c9nfnsx
o.eren
Re: Televizo - IPTV player v1.9.3.21 [Final] [Pro] [Mod]
Post by o.eren »
Dankeschön
andrewjohn
United States of America
Post by andrewjohn »
its quite amazing
andrewjohn
hope it helps
andrewjohn
If you’re into IPTV streaming, Televizo - IPTV Player v1.9.3.21 [Pro Mod] is one of those clean, no-nonsense apps that just works. The modded version unlocks all premium options — no ads, full EPG support, and smoother playlist handling.
You can easily grab it from HappyMod from https://www.happymoodhub.com, where users upload safe, tested versions of popular IPTV and media apps. Just make sure your playlist links (M3U or Xtream) are valid — the app itself doesn’t provide channels.
In short: HappyMod gives you the updated Televizo Pro Mod, while you bring your own streams — perfect combo for anyone who wants full IPTV control without paying extra.
AMISDETOUS
Has thanked: 1 time
Algeria
Post by AMISDETOUS »
Thank you for apk
