Skin BETA-PRO-FHD By bahaa
Has thanked: 14324 times
Been thanked: 1607 times
SKIN Beta-PRO-FHD
by bahaa
This is SKIN valid for
OPENPLI--------- OBH-OPEB --------- ATV---------- OPENSPA--------- EGAMI--------- PURE
Python 2 and Python 3
1-This skin is based on an extra-event plugin to show the poster information.
2-Fix many screens of OPEN-PLI system plugin
3-Many modifications are made to the skin design, and some in the renders and converters.
4- new info bar 1 design with a simple timeshift screen
5-new design to the second info bar
6-new channel selection desgin
7-preview the poster in the single EPG menu
you can setup the skin by using IPK, but i prefer using the Ajpannel to extract the skin .tar files to root directory
3 (1).jpg (162.28 KiB) Viewed 525 times
