Automated CCcam Oscam Multics and cardservproxy (csp) all-in-one installation on Debian
With this plugin I prepared, you sit back and automatically install CCcam-Oscam-Multics r81 and cardservproxy (Csp) on your debian by pressing a button.
you just enter your perks and start sharing or using,
Let's come to the establishment of the program.
1.- Download multics cccam-oscam-csp debian x32-x64 plugin from HERE.
https://www.4shared.com/s/ffxQHsi7hea
ALTERNATIVE DOWNLOAD
http://download1650.mediafire.com/ci6e1 ... x64_3.rar
2.- We extract the files from the rar to the desktop.
3.- Install MulticsCCcamOscamInstall.sh on debian root and chmod 755
4.- We throw the file named cccamoscam_install_package into tmp.
After that, we start to install the program.
5.- We open Putty, we become root
then we enter bash MulticsCCcamOscamInstall.sh and sit back
The program automatically opens the necessary CCCam, Oscam, Multics and Csp files and
It puts it in the necessary places and makes the values 755,
SOFTCAM PLACES
cccam_2.1.3 = /usr/local/bin
oscam = /usr/local/bin
multics = usr/local/bin
csp =/usr/local/
FILE LOCATIONS
CCcam.channelinfo= /var/etc
CCcam.providers= /var/etc
CCcam.prio = /var/etc
CCcam.cfg= /var/etc/
multics.cfg= /var/etc
ip2country.csv = /var/etc
multics.css= /var/etc
baddcw.cfg= /var/etc
cache.cfg = /var/etc
oscam.conf = /usr/local/etc
oscam.server= /usr/local/etc
oscam.user= /usr/local/etc
oscam.services = /usr/local/etc
oscam.srvid = /usr/local/etc
also java, PHP, apache including whatever is required will be installed.
Depending on your internet speed, the installation may take a while, don't worry, you will see how it is loaded on the screen.
at the end, the program will automatically restart your server by counting to 6,
When it is opened again, you will see that all files and information will be uploaded to the relevant places.
I have also added Webinfo page Ports for your convenience..
For CCcam : http:// server ip :16001
For Oscam : http:// server ip : 8888
For Multics: http:// server ip: 5500
For Cardproxy : http:// server ip : 3333
Webinfo user pass in all
User: admin
Pass : admin
you can change the ports, user-pass with whatever you want.
Please use it..
I don't think there will be anything you can't do, if there is, please write or PM me and I will help you..
Also, this complicated plugin is not available in any forum, I am posting it here for the first time.
You can share, I would appreciate it if you would quote me.
NOTE: In order for the program to be installed properly, Debiana must not have any server installed before,
Even if it is installed, backups should be taken, so I am not responsible for deletion and file loss,
also, if the site where the files and images are uploaded does not open, change the DNS address to 8.8.8.8 + 8.8.4.4
Nightblade
- New Member
- Been thanked: 1 time
Re: Automated CCcam Oscam Multics and cardservproxy (csp) all-in-one installation on Debian
Hello, this script does not work on latest Debian 12 when trying to run with either "bash filename" or "sh filename"
: not foundmOscamInstall.sh: 10:
: not foundmOscamInstall.sh: 17:
Script for automated CCcam/Oscam/Multics/Csp installation
sleep: invalid time interval ‘2\r’
Try 'sleep --help' for more information.
chown: invalid user: ‘host\r’
MulticsCCcamOscamInstall.sh: 224: Syntax error: end of file unexpected (expecting "then")
- 5037 Views
- 5205 Views
Last post by yugoslavia
- 14151 Views
Last post by lider
- 1640 Views
Last post by VivaEuropeTV
- 36 Replies
- 18248 Views
Last post by falchon
