Notepad++ [*.Latest version] 👈🏽🔰🔰✅
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
Re: Notepad++ [*.Latest version] 👈🏽🔰🔰✅
Notepad++ v8.7 Release
New update:17.09.2024
1. Update to scintilla 5.5.2 & Lexilla 5.4.0.
2. Fix monitoring large files with frequent writes freezing the UI issue.
3. Fix regression of multiple selections in comboboxes of Find dialog.
4. Fix a single undo reverting many changes issue.
5. Improve Styler Configurator performance considerably.
6. Fix CVE-2014-9456 (but CVE-2014-9456 is not a "Security Vulnerability").
7. Make find dialog status messages color customizable via Style Configurator.
8. Make individual tab color customizable via Style Configurator.
9. Add new plugin command NPPM_GETNATIVELANGFILENAME & notification NPPN_NATIVELANGCHANGED for native language being changed.
10. Fix Folder as Workspace sorting problem for network storage (Samba, WebDAV, WSL, etc.).
11. Fix closing unsaved clone document causing periodic backup loss issue.
12. Fix Style Config's "User-defined keywords" not being saved properly after emptying it.
13. Add user-defined keyword ability for some supported programming languages (ActionScript, ASP, Bash, C, C++, C#, GDScript, Go, HTML, Java, JavaScript).
14. Add Fluent Icons for enhancing FunctionList, Folder as Workspace & project panels' icons in lite mode.
15. Fix Python smart indent issue when a string or comment line ends with a colon.
16. Add file type filters for UDL in Save dialogs.
17. Add TOML language (TOML format) support.
18. Add function list for TeX/LaTeX.
19. Recognize Cython files as Python.
20. Fix edit zone not getting focus while clicking the active tab.
21. Add the ability to open the copy automatically after the “Save a Copy” command.
22. Fix inability to paste after removing read-only via menu.
23. Add one more option for auto-indent so C-Like language indent can be disabled.
24. Fix Style Configurator regression: "URL hovered"'s "Go to Settings" not working.
Download Notepad++ v8.7
https://notepad-plus-plus.org/downloads/v8.7/
- Been thanked: 2735 times
Notepad++ v8.7.1 Release
New update:04.11.2024
1. Update cURL in Notepad++ updater (WinGUp) for fixing cURL's CVE-2024-7264 issue.
2. Fix opened network files hanging while the network disconnected.
3. Fix not being able to open folder via cammand argument regression.
4. Update to Scintilla 5.5.3 & Lexilla 5.4.1.
5. Fix modified Find dialog status msg colors not being remembered through sessions.
6. Fix hanging issue while hiding lines.
7. Make left behide hide line close marker removable.
8. Fix Find dialog status bar wrong messaging (regression).
9. Fix URL parsing issue with '?' after '#'.
10. Add "Close to system tray" ability.
11. Add tab created time tooltip for new opened untitled tab.
12. Improve GUI to avoid user confusion between Global override & Default Styles.
Download
https://notepad-plus-plus.org/downloads/v8.7.1/
Download
Latest Version of Notepad++
Notepad++ v8.7.2 Release
New update: 27.11.2024
1. Add Pin tab feature.
2. Tabbar enhancement: Hide inactive tab Close & Pin buttons.
3. Tabbar enhancement: Highlight inactive darken tab on mouse hover.
4. Fix Ctrl-C not doing copy from Search result issue.
5. Add "Minimize / Close to" option for System tray.
6. Add ability to open/copy selected files from Search-results.
7. Fix replace field focus losing when Notepad++ is switched back.
Download Notepad++ v8.7.2
https://notepad-plus-plus.org/downloads/v8.7.2/
Notepad++ v8.7.3 Release
New update: 31.11.2024
1. Fix a crash while disabling "Pin tab" feature.
2. Fix drag&drop a folder in Notepad++ launch redundant dialog regression.
3. Fix docked panels invisibility in multi-instance mode.
4. Add "Pin/Unpin Tab" context menu item.
5. Add "Close All BUT Pinned" command.
6. Fix a possible buffer overflow issue.
Download
https://notepad-plus-plus.org/downloads/v8.7.3/
Download
Notepad++ v8.7.4 Release
New update: 05.12.2024
1. Fix regression of multi-line tabbar height not updated after closing tabs.
2. Fix the extension defined by user not override language default extensions.
3. Fix encoding of nfo file cannot be changed bug.
Download Notepad++ v8.7.4
https://notepad-plus-plus.org/downloads/v8.7.4/
Notepad++ v8.7.5 Release
Fixed problem with loss of changes in nfo file (regression from version 8.7.4).
Fixed detection of incorrect network file modification (regression from version 8.7.1).
Fixed a regression that caused the “Open selected PathName(s)” command to fail when all paths were selected.
Fixed inability to use after deleting split files.
Fixed
A bug that caused unsaved documents to be lost on the next
launch if portable Notepad++ changed the path.
Refactoring for better performance and smaller binary code.
Improved “Copy selected lines” command.
Added a list of Visual Basic functions.
Added Swift, TypeScript and Go for advanced automatic indentation.
Fixed a bug that caused the UDL comment string to fail due to a conflict with the thread comment definition.
Improved the “Track current document” GUI action/option in the “Search in files” function.
Fixed a bug that caused the workspace reload function to not work.
Added “Show details” feature to the installer.
https://notepad-plus-plus.org/downloads/v8.7.5/
Fixed
Notepad++ v8.7.6 Release
New update: 28.01.2025
1. Update to scintilla 5.5.3 & Lexilla 5.4.1.
2. Enhance performance of syntax highlighting for large files.
3. Make "Show close/pin button on each inactive tab" optional.
4. Add ShortcutMapper Multilingual ability, allowing the use of specific keys for non-en-US keyboards.
5. Fix vertical tab crashes when enabling/disabling the pin tab feature.
6. Fix crash when passing an invalid buffer with NPPM_SETUNTITLEDNAME.
7. Fix floating panels position resetting regression in multi-monitor configurations.
8. Fix incorrect "Replace all" behavior during the second replace in selection.
9. Fix backup file renaming bug for untitled tabs.
10. Enhance UX in "Find in file" action when the Directory field is empty.
11. Make the current line/position copyable in the Go to Line dialog.
12. GUI enhancement: hide right menu shortcuts on the fly.
13. Minor enhancements for JavaScript, CSS & HTML.
https://notepad-plus-plus.org/downloads/v8.7.6/
Notepad++ v8.7.7 Release
Add new API NPPM_ADDSCNMODIFIEDFLAGS for some plugins to fix eventual regression regarding SCN_MODIFIED. (Fix #16121)
Download
https://notepad-plus-plus.org/news/v877-released/
Download
Release Date: 2025-04-02
Notepad++ Current Version 8.7.9
https://notepad-plus-plus.org/downloads/v8.7.9/-
- 3977 Views
- 5199 Views
- 88 Replies
- 8865 Views
- 439 Views
- 421 Views
