Notepad++ [*.Latest version] 👈🏽🔰🔰✅
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Re: Notepad++ [*.Latest version] 👈🏽🔰🔰✅
#11
Post by sugar »
Notepad++v8.5.8 Release
New update:17.10.2023
1. Fix "Clear Read-Only Flag" command not working immediately regression.
2. Fix saving files losing Alternate Data Stream issue.
3. Fix data loss issue due to no room on disk for saving.
4. Add Win10/Win11 Restart-application feature.
5. Fix user created session being modified behaviour on exit.
6. Improve document list display performance.
7. Update Scintilla to v5.3.7 & Lexilla to v5.2.7.
8. Fix unwanted Afrikaans installer language issue.
9. Fix a crash issue while reading settings from cloud.
10. Fix security issue CVE-2022-31901.
11. Enhance non-saved search text's persistence in Find dialog combobox while pressing arrow key.
12. Make auto-checking of Find InSelection configurable (resizable & can be disabled).
13. Perl enhancement: Update Stylers & the keywords for Perl v5.38.
14. Fix "Single Line Uncomment" uncommenting an extra line issue.
15. Fix "Next Bookmark" command not resetting current column issue.
16. Allow menu command Window->Windows to be assigned a shortcut.
17. Fix wrong categories in Shortcuts Mapper.
Download Notepad++ v8.5.8
https://notepad-plus-plus.org/downloads/v8.5.8/
sugar
Global Moderator
Global Moderator
#12
Post by sugar »
Notepad++ v8.6 Release
New update:23.11.2023
1. Multi-edit is fully supported in Notepad++.
2. Make multi-select background & caret colours customizable.
3. Make session inaccessible files remembered (empty & read-only document as placeholder).
4. Fix missing session invalid error for user session & enhance API NPPM_GETNBSESSIONFILES.
5. Fix network shared files saving regression.
6. Update Scintilla to v5.3.8 & Lexilla to v5.2.8.
7. Fix docking panel crash due to messing up config.xml.
8. Fix invalid styler.xml making Notepad++ crash issue.
9. Fix tab-closing crash by middle mouse button (unexpected mouse position).
10. Fix 2 performance issues in Style Configurator.
11. Add 3 line operation (delete, copy & cut) shortcuts.
12. Display extra info in the status bar of Find/Replace dialog to avoid PEBKAC.
13. Fix "Hide lines" command hiding unselected lines issue.
14. Fix silent installer mode when Notepad++ is running issue.
15. Fix Updater's vulnerability (update cURL in WinGUp for fixing CVE-2023-38545).
16. Fix incoherent behaviour of "Duplicate Current Line" menu command.
17. Fix JSON5 not using JSON keywords.
18. Fix empty message showing while cancelling session file saving dialog
Download Notepad++ v8.6
https://notepad-plus-plus.org/downloads/v8.6/
sugar
Global Moderator
Global Moderator
#13
Post by sugar »
Notepad++ v8.6.1 Release
New update:05.01.2024
1. Updated to Scintilla 5.4.1 & Lexilla 5.3.0.
2. Fix a regression: the position in the previous session is now restored correctly in cloned document.
3. Fix a regression: customized extension in Style Configurator is now saved correctly.
4. Add an ability (disableLineCopyCutDelete.xml) to disable line copy/cut/delete when no selection is made.
5. Add an ability (noColumnToMultiSelect.xml) to disable column mode to multi-select mode.
6. Fix deleting in column mode also delete an unexpected EOL.
7. Fix hidden results of long lines for Search results with "Find in..." commands.
8. Enhance Search-results by showing search options for "Find in..." commands.
9. Fix an issue: replacements are no longer duplicated (the 2nd time in cloned document) for "Replace in Opened Docs".
10. Fix a regression to make F3 & Shift-F3 work again in Incremental Search.
11. Add document tab navigation commands: "First tab" & "Last tab".
12. Add document tab commands: "Move to Start" & "Move to End" commands.
13. 3 RTL new abilities: RTL per document, RTL per document remembered across the sessions & new attribute editZoneRTL="no" in RTL localization files.
14. Enhance the "-loadingTime" command line parameter.
15. Enhance the performance: disable undo collection while loading a file.
16. Sort language list in the Preferences dialog.
17. Fix a visual glitch that occurred during multi-paste.
18. Fix confusing memory allocation error message.
19. Fix python wrong decorator attribute color.
20. Fix file status in "other view" is not detected.
21. Fix dropped file being opened in the wrong view.
Download Notepad++ v8.6.1
https://notepad-plus-plus.org/downloads/v8.6.1/
sugar
Global Moderator
Global Moderator
#14
Post by sugar »
Notepad++ v8.6.2 fixed
Fix Shift-DEL, Ctrl-INS and Shift-INS not working regression. (Fix #14470, #14571)
Fix Ctrl+V cannot paste into the text fields of certain plugins regression. (Fix #14568)
Remove option “disableLineCopyCutDelete.xml” (the empty file takes no effect).
Fix a regression: the position in the previous session is now restored correctly in cloned document. (Fix #14164)
Download Notepad++ v8.6.2 | Notepad++
https://notepad-plus-plus.org/downloads/v8.6.2/
sugar
Global Moderator
Global Moderator
#15
Post by sugar »
Notepad++ v8.6.3 Release
New update:18.02.2024
1. Restore multi-editing option & add "Column To Multi-editing" option on GUI.
2. Make "copy/cut line while no selection" optional.
3. Fix all open files lost after restarting as Admin to save a file.
4. Fix "Replace All" crash & performance issue.
5. Fix calltip crash due to the division by zero.
6. Enhance Function List for Python to support "async def" & colons in argument list.
7. Fix Copy/Cut/Paste issue in Vertical Edge text field in preferences dialog.
8. Fix macro recording twice for some commands.
9. Fix "Open File" command not working with TAB preceded.
10. Add auto-completion keywords for PHP, JavaScript and CSS.
Download Notepad++ v8.6.3
https://notepad-plus-plus.org/downloads/v8.6.3/
sugar
Global Moderator
Global Moderator
#16
Post by sugar »
Notepad++ v8.6.4 Release
New update:20.02.2024
-Fix regression that the view cannot be activated by mouse clicking..
Download Notepad++ v8.6.4
https://notepad-plus-plus.org/downloads/v8.6.4/
ocean777
E2 Developer
E2 Developer
Has thanked: 239 times
Been thanked: 210 times
Andorra
#17
Post by ocean777 »
Notepad++ v8.6.5 Release
New update:30.03.2024
1. Fix "Replace All" action not notifying plugins of modification regression by adding NPPN_GLOBALMODIFIED.
2. Fix plugins not receiving some Scintilla notification types regression.
3. Fix Shortcut Mapper pontential crash problem.
4. Fix period backup pontential crash due to the dead lock.
5. Fix NUL characters file corruption after power outrages.
6. Remedy losing session problem after power outrages.
7. Fix URLs are not detected after a "Replace All" regression.
8. Notify user while saving failure due to hardware problem.
9. Update to scintilla 5.4.3 (from 5.4.1) & Lexilla 5.3.1.
10. Support template literal (template strings) in JavaScript & make `back-quoted strings` more readable.
11. Add support for Change History in the text, besides in the margin. Also, make Change History color configurable.
12. Fix NPPM_RELOADFILE API return wrong result issue.
13. Enhance Shortcut Mapper filter to find command items more easily
14. Prevent typing control characters into document & make it optional.
15. Fix possible no-GUI state when using systray.
16. Make context menu popup location at current text position when invoked via keyboard.
17. Fix Notepad++ blocked when closed minimized or from systray.
18. Fix python wrong decorator attribute colors & add "ATTRIBUTE" color in styles.xml.model.
19. Fix Mouse Wheel Scrolling in Shortcut Mapper & reduce also the memory use.
#18
Notepad++ 8.6.6 release
Notepad++ v8.6.6 bug-fixes & new enhancements:
1. Update to scintilla 5.5.0 & Lexilla 5.3.2.
2. Fix crash when crossing the 2GB file size threshold.
3. Fix a performance issue due to URL recognition.
4. Update to nlohman json 3.11.3.
5. Fix multi-edit resists escape after typing issue.
6. Make F3 & Shift-F3 work in Find Replace dialog.
7. Allow Ctrl-TAB to switch tabs in FindReplace, PluginAdmin and UDL dialogs.
8. Add programming language support for Go & Raku(Perl 6).
9. Fix user defined auto-insert not working issue.
10. Enhance GUI: resize checkboxes/radio buttons as text length needs.
11. Enhance GUI: make sizing arrows more coherent in Find dialog.
12. Fix URL enclosed in apostrophes or backtick not working issue.
13. Fix wrong dropped file view issue.
14. Fix Korean(한)/English(영) key not working regression.
15. Fix the tab labels of some dialogs being cut in Dark mode.
16. Fix close button disappeared issue in Find Replace dialog.
17. Apply dark theme to checkbox buttons on Windows 11.
18. Fix menu bar cluttered in Dark Mode issue.
19. Fix Debug Info minor display regression.
20. Enhance Lua language syntax highlighting.
21. Enhance the function list support for Ada.
https://notepad-plus-plus.org/downloads/v8.6.6/
#19
Notepad++ v8.6.7 Release
New update:13.05.2024
1. Fix regression of multi-edit cursors placed wrongly issue.
2. Fix multi-editing not showing multiple cursors in dark mode.
3. Add auto-completion for Go & Raku, function list for Raku.
4. Fix symbol '&' not showing in Document Switcher.
5. Allow syntax highlighting for custom tags in HTML.
6. Fix dialogs out of screen problem.
https://notepad-plus-plus.org/downloads/v8.6.7/
sugar
Global Moderator
Global Moderator
#20
Post by sugar »
Notepad++ v8.6.8 Release
 New update:04.062024
    1. Fix a crash in Column Editor caused by an arithmetic overflow.
    2. Fix the issue where any negative repeat value in Column Editor causes a hang.
    3. Fix an extra space being inserted in HEX mode issue in Column Editor.
    4. Fix a visual glitch of the toolbar pressed buttons in dark mode.
    5. Add auto-indent feature for Python.
    6. Fix the issue where "show control characters" settings not remembered when switching to another tab.
    7. Fix the missing monitoring disabled state icon from the fluent icon set on the toolbar.
    8. Adjusted the inaccurate naming of indent settings in thee Preferences dialog.
    9. Fix the issue where the customized color of active tab in inactive view is missing.
    10. Introduce a new plugin command "NPPM_GETTABCOLORID" to retrieve the current tab color ID.
    11. Allow the tree view dark mode customization for plugins.
    12. Fix the popup dialog for updating not metioning 'Notepad++'.
Download Notepad++ v8.6.8
https://notepad-plus-plus.org/downloads/v8.6.8/
