Last Version of Zoom Player🧿⭐✅🔥
sugar
Global Moderator
Global Moderator
Has thanked: 73 times
Post by sugar »
Zoom Player update New Version...09/04/2022
- 16.5 / 17 Beta 3
 New Setting (Adv. Options / Playback / Video / Subtitles) that limits the "next subtitle" feature to specified languages. For example to limit the subtitle tracks to Spanish, English and Directory Commentary, you only need to specify "spa;eng;dir" and any subtitle track not containing these values will by skipped when switching to the next subtitle track.
- New "exSetAudioSync" extended function that allows you to set a positive or negative millisecond accurate audio synchronization offset.
- Added support for YouTube Shorts URL parsing and playback, for example: https://www.youtube.com/shorts/5TTNpKFy_10 Change :
- YouTube media library plugins no longer return a star rating or dislike
count since YouTube removed public dislike data.
- The "Pause playback when minimizing the player window while playing video content" setting is now ignored for live streams with no duration
specified as it just caused the stream to close.
- Disabled the Startup sound if a media was already in the process
of loading.
- The Media Library's function page is now more dynamic, removing entries that may not be useful in some contexts (e.g. using plugins).
- TheMovieDB scraper plugin will now download movie poster images at full resolution (previously limited to 500x750px). This change means you will
see sharper looking posters on 4K displays. This fix requires that you re-scrape movies to download the higher resolution poster images.Fixes :
- Seeking Ahead/Back on YouTube streams using the IFRAME player would reset the play position to 0 if the windows decimal separator was
set to something other than ".".
- Restoring last play position for YouTube videos played using the IFRAME player did not function currently on some PCs with a slower internet
connection.
- Displaying the current video resolution on the timeline while using the YouTube IFRAME playback engine displayed a fixed value instead of the value returned by the YouTube IFRAME engine.
- The "Open Media Library" button on the Media Library category editor did not function if the category mode was set to view all (prism).
- YouTube channels containing the "&" character in the name would not show the correct channel name under some conditions.
- Fixed a cosmetic bug in the play history dialog that would show the current position with a negative value.
- Edits to the playlist using the playlist editor should now be reflected in the advanced playlist control interface.
- The playing information fullscreen navigation interface was not updating in real time and didn't update at all when playing new SHOUTcast content.
- The "Open Drive" feature broke down for multiple use cases, including using Zoom Player to auto-play a drive.
- The Media Library's "mark as seen:archive" option will now close the currently playing media if it's being archived.
https://www.videohelp.com/download/zp17 ... rbZsXDfNPD
sugar
Global Moderator
Global Moderator
Re: Last Version of Zoom Player🧿⭐✅🔥
Post by sugar »
Latest version
17.1 (November 9, 2022)
--- What's new in Zoom Player v17.1:
* New "Display unwatched counter on TV Show category folders" setting (Adv. Options / Interface / Fullscreen Navigation / Thumbnail Cust.) that counts the number of unwatched episodes in "TV Show" categories and displays the count in a corner on the folder's thumbnail.
* Full customization for the TV Show unwatched counter: 1. Size (relative to thumbnail) 2. Margins (relative to Size) 3. Font Color 4. Background Color
* New "Display thumbnail season progression bar" setting (Adv. Options / Interface / Fullscreen Navigation / Thumbnail Cust.) that shows a season progression bar (similar to the last play position bar) in TV Show category based on the number of watched/unwatched episodes in a folder.
* New "Reset" option in each individual media library filtering mode (Genre, Tag and Collection).
* Two new Pixel Shader scripts you can use with MadVR as the video renderer to flip the video both horizontally and vertically.
+ Filtering the media library will now reset the selected entry to the first item, unless the "Auto-select last viewed file/folder on entering a folder" setting is enabled, in which case the last viewed file or folder is selected automatically.
+ If you previously used a download tracking plugin, you must now re-enable it. Plugins were previously enabled by default which could have caused delays when exiting Zoom Player.
+ Having ZP set to automatically show the media library when opening will no longer show the media library if a media was set to load using the command line.
+ Zoom Player will no longer display the default background image if a media is set to load via command line, removing the slight flicker of the image and slightly speeding up load time.
- Setting Zoom Player to pre-load fullscreen navigation graphics while trying to play a media from command line could cause ZP to freeze.
- When taking a screenshot of the playing video (Alt+F), the generated filename included a wrong position value (just the file name, the image was taken from the correct position).
- The "Stop function closes streaming media (instead of just stopping)" setting was accidentally applied to every playing media and not only live streams.
- Fixed a bug that would break URL links in the active playlist when closing and then re-opening Zoom Player.
Download Zoom Player 17.1
https://www.videohelp.com/software?d=zp1710free.exe
sugar
Global Moderator
Global Moderator
Post by sugar »
Latest version
17.2 / 18 Beta 4 (September 27, 2023)
--- What's new in Zoom Player v18 beta 4:
New :
* The IPTV auto-updating EPG and Stream List downloads can now handle
".zip" and ".gz" archive URLs (e.g. "https://website.com/epg.zip").
* New Filter EPG feature on the IPTV interface.
* New IPTV setting (Adv. Options / Playback / IPTV) that controls the
EPG font size.
* New IPTV setting (Adv. Options / Playback / IPTV) to control whether
the EPG filter checks program description or only the program's title.
* New "Custom Action" button on the main window (near the top-left) that
allows you to set any standard Zoom Player function to the button.
By default this button opens the new IPTV interface.
* New Setting (Adv. Options / Interface) that allows you to assign a
function to the new "Custom Action" button.
Fixes :
- The IPTV interface should feel a bit smoother (less flickering).
- In the media library's category editor, specifying a category name
containing unicode characters would not highlight the entry in
the category list after clicking.
- Media Title containing certain unicode characters (e.g. emoji) did
not show when loading some playlist formats (m3u, asx, b4s, wpl).
Download Zoom Player 18 Beta 4
https://www.sendspace.com/file/l5mwj0
sugar
Global Moderator
Global Moderator
Post by sugar »
Latest version
17.2 / 18 Beta 5 (October 4, 2023)
--- What's new in Zoom Player v18 beta 5:
New :
* You can now select IPTV streams as favorites and they automatically
show up under a "Favorites" group at the start of the stream list.
You can right click a favorite stream to re-arrange or sort your
favorites list or simply remove the stream from the favorites section.
* You can now hide IPTV groups from being listed by right-clicking the
group and selecting "Hide Group" or through the options dialog.
* Right-clicking an IPTV EPG entry will now show the program's description
and allow you to set a notification to remind you that the program is
about to start as well as specify that you want to automatically switch
to the program's stream in due time.
Notifications are remembered even if you close and re-open Zoom Player,
but they will not activate if Zoom Player is not running.
* New Hidden IPTV Group controls (Adv. Options / Playback / IPTV).
* New Setting (Adv. Options / Interface / Control Bar / Timeline Area)
that allows you to control whether the timeline displays the current
playlist track number.
You can also toggle this setting through the control bar menu by
right-clicking the timeline with nothing playing (or middle-clicking
if something is playing).
* The Advanced Playlist Control interface is now accessible through the
right-click menu under the "Open Interface" section.
Change :
+ Optimized EPG parsing, improving load time by 5-15%.
+ The playlist editor's search feature has been enhanced to support
repeated search. Simply press Enter to cycle between all entries that
contain the searched term.
+ The Station Manager window now has an "X" in the corner to close the
window (previously you had to click the "close" button).
Fixes :
- The Media Libary's category editor's "Playlist" category option did
not display categories correctly if they had certain unicode characters
in the name (e.g. Emojis).
Download Zoom Player 18 Beta 5
Latest version
New :
Change :
Fixes :
Download Zoom Player 18 Beta 5Latest version
New :
Change :
Fixes :
https://www.sendspace.com/file/zmm84b
sugar
Global Moderator
Global Moderator
Post by sugar »
Latest version
17.2 / 18 RC1 (November 15, 2023)
--- What's new in Zoom Player v18 release candidate 1:
New :
* Opening the IPTV interface for the first time now offers you the option
to automatically download free, child-friendly, publicly available IPTV
channels from around the world through the Free-TV project:
github.com
GitHub - Free-TV/IPTV: M3U Playlist for free TV channels
M3U Playlist for free TV channels. Contribute to Free-TV/IPTV development by creating an account on GitHub.
github.com github.com
* Using the "Play Stream" button on the IPTV interface will no longer try
to play an EPG program and will always try to play the channel live.
* New "Play Program" button on the IPTV interface. The "Play Program"
button is used to play archived IPTV programs. If the channel does not
support archive playback or tif he selected program is no longer
(or not yet) archived, the "Play Program" button will remain disabled.
* New "Add Free Channels" button (Adv. Options / Playback / IPTV) that
adds free, child-friendly, publicly available IPTV channels from around
the world through the Free-TV project.
* You can now control outdated EPG programs background colors
(Adv. Options / Playback / IPTV), making it easier to distinguish
which programs have already aired.
* Support for more IPTV Archive playback schemes.
* New Setting (Adv. Options / Playback / IPTV) to specify the symbol
used to highlight archive channels in the IPTV stream list.
Fixes :
- No longer marking IPTV channels as archive if their "catchup-days"
value is "0".
- That Playlist Editor's search box did not support unicode characters.
- You can now use Ctrl+V to paste Unicode text into the Playlist Editor's
search box (including special characters such as Emoji).
- Fixed a bug that could cause Zoom Player to freeze when trying to
play YouTube URLs containing a space character after the URL.
--- What's new in Zoom Player v18 beta 10:
New :
* Support for IPTV Archive playback. For channels that support it,
double-click the program to start playing it. You can easily identify
Archive supporting channels by the icon next to their name.
There are multiple implementations of IPTV Archive support and I did
my best to make sure all were covered, but if something is not working
as intended, let me know on Zoom Player's sub-reddit.
* New IPTV Setting (Adv. Options / Playback / IPTV) that clears the
playlist before streaming. This setting is enabled by default,
disabling it adds the channel to the playlist and play it without
clearing the playlist.
* New Setting (Adv. Options / Interface / Playlist) to prevent embedded
playlists (playlist files within playlist files) from loading when
Zoom Player loads a playlist. This setting is enabled by default as
embedded playlist can lead to unfortunate infinite-loops cases and
other stability problems.
Change :
+ Playing media from the Advanced Playlist Control now ensures the newly
played item is visible in the Playlist Editor.
+ I Didn't like the behavior of the new setting (enabled by default)
that automatically hide the control bar when clicking the video area.
What annoyed me was that it was canceling my action, so if I wanted
to pause the video, it would ignore the pause action and just hide
the control bar. Now I adjusted this feature to hide the control bar
and not block the intended action.
Fixes :
- Fixed a bug that caused the IPTV caches to get wiped clear when Zoom
Player was pruning the media library thumbnail and meta-data cache.
- Playing an entry from the Advanced Playlist Control interface no longer
loses the entry's selection.
--- What's new in Zoom Player v18 beta 9:
New :
* Added a clock to the top of the IPTV's Electronic Program Guide section.
* Added a button to clear the IPTV channel logo cache (Adv. Options /
Playback / IPTV). Clearing the logo cache forces Zoom Player to
re-download the channel icons.
Change :
+ If an IPTV channel doesn't have a logo or ID in the M3U playlist file,
Zoom Player now tries to use an icon from the EPG XML file based
on the channel name (or partial name) and caches the logo so it shows
even if you keep the EPG panel closed.
+ IPTV Stream Channel -> EPG matching by Channel name (when a Channel ID
is not present) now works when the EPG contains multiple channel names
for the same channel.
is not present) now matches even if there is an uppercase/lowercase
mismatch in the name or the EPG contains only a partial name.
+ IPTV Stream Channel -> EPG matching by Channel name is now automatic if
no EPG data was found using the Channel's ID.
+ The IPTV section of the options dialog is now a lot more informative
with regards to the Playlist/EPG download status (or failure).
+ Closing and re-opening the IPTV interface will now maintain the
EPG listing.
Fixes :
- Refreshing the IPTV list after a new Playlist or EPG finished downloading
should now maintain open groups and EPG listing.
- Fixed a bug that prevented some IPTV channel logo from saving properly
and may have even caused the wrong icon to show up for some channels.
- The IPTV Stream list did not display correctly if specifying a DPI value
higher than 100% in Zoom Player's options.
--- What's new in Zoom Player v18 beta 8:
New :
* New Wakeup on LAN feature (Adv. Options / System) that allows you to
turn on PCs. This feature is extremely useful when using NAS (Network
Attached Storage) devices as your source for the media and you only
want to turn them on when using Zoom Player.
With this new feature, you can specify multiple MAC addresses to wake
several PCs and you can trigger the wake-up action with a choice of
conditions such as:
1. When starting Zoom Player
2. When opening the Media Library
3. When opening the File Navigator
If there are other use-cases where you would want Zoom Player to
wake-up remote PCs, let me know.
* New button on the IPTV Interface to toggle 50% window transparency.
* New IPTV setting to merge duplicate channels. This can be useful
if you're using multiple EPG files/links that contain EPG info
on the same channel.
* New IPTV setting (enabled by default) to keep the IPTV interface
window on top of other windows and applications while Zoom Player
is in fullscreen mode.
* New IPTV setting to control the screen ratio between the stream list
and the EPG. The default value is 1:1.5 (Making the EPG 150% wider
than the stream list).
* If an IPTV channel doesn't have a logo in the M3U playlist file,
Zoom Player now tries to use an icon from the EPG XML file and
caches the logo so it shows even if you keep the EPG panel closed.
Change :
+ To prevent distracting confirmation messages popping up, the IPTV
interface no longer prompts you to update the list once an IPTV M3U
playlist or XML EPG finished downloading, instead it will enable a
refresh button which you can click at your leisure.
+ Enhanced IPTV stream list keyboard navigation.
+ When opening the IPTV interface with the EPG hidden, the EPG data will
not load until the EPG section is opened which results in the IPTV
interface becoming accessible faster.
+ When loading IPTV playlists, if a channel does not contain ID
information, Zoom Player will try to match EPG entries based on
the channel name instead.
+ IPTV channel logos should appear faster if there are broken links in
the M3U playlist file.
+ Closing and opening the IPTV interface window now restores the previously
opened group layout.
Fixes :
- Resizing the IPTV interface window could leave trails on screen until
the stream list was scrolled.
- Right clicking a history entry and selecting "copy" in the playback
history interface returned a jumble result when copying links.
- The scroll bar on the description section of the IPTV program information
dialog accessible by right-clicking an EPG program did not show/hide
properly based on the window size.
--- What's new in Zoom Player v18 beta 7:
New :
* You can now easily multiply Zoom Player's windowed skin resolution
from the skin selection dialog (press "N" to open) to better match
Zoom Player's skin to your monitor's resolution.
* You can now time-shift IPTV channels in the EPG by right-clicking an
EPG entry.
* New IPTV Safe mode setting (Adv. Options / Playback / IPTV) that
blocks access to Hiding Groups, Adding/Modifying favorites and
EPG Time Shifting.
Change :
+ Zoom Player will load slightly faster when using a multiplied
resolution skin.
+ Zoom Player's title text now scrolls if there is no room to show
the entire text.
Fixes :
- Filtering the media library by Genre stopped working.
--- What's new in Zoom Player v18 beta 6:
New :
* This feature has been requested by many. The ability to scale
Zoom Player's skinned windows to make them easier to use on
4K and 8K displays:
New Setting (Adv. Options / System) that allows you to resize
the current windowed skin by 200-800%. Please note that this
setting may not work well with some older Zoom Player skins.
* New button added to the IPTV interface that allows you to toggle
the EPG display on and off.
* New IPTV setting (Adv. Options / Playback / IPTV) to hide old EPG
entries (programs that have already aired).
* New Search feature in the media library category editor.
Change :
+ Redesigned the media library category editor layout. Hopefully it's
clearer and easier to work with.
+ Pressing ESC with the player window in focus now closes the IPTV
interface window.
+ Pressing ESC now closes the "Patterns" interface instead of having
to cycle through every pattern.
Fixes :
- You can no longer set an IPTV program start notification or switching
to the live stream if the EPG entry is older than the current time
(has already finished airing).
- The IPTV notification message before a program starts will now remain
visible for several more seconds.
- Loading M3U playlists containing links to ot...
Download Zoom Player 17.2
https://www.videohelp.com/software?d=zp1720free.exe
Download Zoom Player 18 RC1
https://www.sendspace.com/file/9u18ps
sugar
Global Moderator
Global Moderator
Post by sugar »
Latest version
18 / 19.0 Beta 2 (January 24, 2024)
--- What's new in Zoom Player v19 beta 2:
New :
* Running Zoom Player on a fresh install will now asks if you would
like to enable "Performance Mode".
Choosing "Yes" does two things:
1. Enables D3D11 hardware accelerated video decoding in LAV Filters,
a requirement for smooth 4K video playback.
2. Sets the Video Renderer to MadVR, enabling HDR video support,
high quality video scaling, hardware accelerated subtitle
rendering and smoother motion.
Both settings can be modified in the advanced options dialog:
* A new "Help" section has been added to the right-click menu. The new
help section can quickly bring up the keyboard shortcut list or quick
usage guides for many of Zoom Player's popular interfaces.
* New keyboard macros to toggle libVLC playback:
Alt+"6" - Toggle libVLC IPTV playback (enabled/disabled)
Alt+"7" - Toggle libVLC BluRay playback (enabled/disabled)
Alt+"8" - Toggle libVLC Media file playback (enabled/disabled)
Alt+"9" - Toggle libVLC Streaming playback (enabled/disabled)
These toggles still require that you re-open the playing media
to take affect.
* The right-click menu has been extended with a new "Help" section.
The help section provides quick access to the keyboard shortcut list
and quick usage guides for most of Zoom Player's interfaces.
* The Play History dialog (Alt+"H") has gotten a face-lift, an option
whether to clear the playlist when playing from history, a button
that automatically sets the column sizes based on the current window
size and you can drag the play history window with the mouse by
clicking in any empty space.
* New "/infojson" command line parameter that can be used to query
a running instance of Zoom Player for information. The results
are returned in the windows clipboard as a UTF8 encoded JSON string.
This feature can be used in combination with Window's Powershell to
monitor and control Zoom Player entirely through the command line,
without requiring a TCP/IP connection to access the more advanced API.
Special characters are encoding using standard JSON character encoding.
If no additional parameters are specified, all fields are returned.
To get specific results, you can use a combination of one or more of
the following:
PlayState - A number representing the current play state where
0 : Closed
1 : Stopped
2 : Paused
3 : Playing
MediaName - UTF8 string containing the playing file name or URL.
Title - UTF8 string containing the playing media's title.
Position - The playing position in seconds.
Duration - The playing duration in seconds.
PlayIndex - The current playlist play index.
Playlist - UTF8 string containing the current playlist, each media
entry is specified as a part of a JSON array.
AudTrack - The current audio track number.
SubTrack - The current subtitle track number.
Example to get the playing media name, title, duration and position:
zplayer.exe /infojson:MediaName,Title,Duration,Position
Change :
+ The keyboard shortcuts list (F1 keyboard shortcut) is now a single
dialog which opens much faster and is no longer a part of the options
dialog which takes longer to open.
+ The "Toggle Control Bar" right-click menu option has been re-located
to the menu's root level.
+ If the playing media has only one audio track, it will no longer
be listed in the Stream Selection section of the right-click menu.
+ If MadVR is selected as the Video Renderer without being installed,
Zoom Player now notifies you and falls back to the EVR renderer.
Fixes :
- A bug caused some information dialogs to show the information in
the window's title and the actual title in the windows body.
- Fixed several libVLC related bugs,
Download Zoom Player 19.0 Beta 2
zp1900b2max.rar (39.67MB)
https://www.sendspace.com/file/ls6cj1
sugar
Global Moderator
Global Moderator
Post by sugar »
- What's new in Zoom Player v19 beta 3:
New :
* You can now use libVLC to cast the playing video to supported ChromeCast
devices. All you need to do is open "Adv. Options / Playback / libVLC" and
scan for the ChromeCast device. Any content played through the libVLC engine
will now display on the selected device. Please consider that it can take a
few seconds longer to open media files for casting.
* MPC-VR can now be selected as a Video Renderer for media playback. It is
not fully supported (subtitles, pixel-shaders and other unique features
for the video renderer will not work presently.
* New Setting (Adv. Options / Playback / Control) that allows you to rollback
the current play position when resuming playback from the Pause state. This
feature is useful if you have an external receiver that requires a few
seconds to restore the audio when playback resumes.
Change :
+ If you previously used as Custom Video Renderer for media playback, you must
re-select the custom option (Adv. Options / Playback / Video).
+ Using the Next/Previous Track features now ensures the newly loaded track
is visible in the playlist editor.
+ Cleaned up some dialogs that had elements that were too close together,
especially under Windows 11.
Fixes :
- Scraping TheMusicDB should work once again.
- When Zoom Player's DSP filter is unable to connect to the audio renderer,
the DSP filter is now removed so Smart Play will not fail (fallback to
Microsoft's method of choosing components can be unstable), increasing
overall stability for badly authored media files.
- Fixed a bug that caused the media library background image to be overlaid
twice with a slight offset, slowing down opening a folder in the media
library a little bit and causing visual ghosting effects (was really hard
to see with the default background image).
Download Zoom Player 19.0 Beta 3
https://www.zptechnology.com/download/zp1900b3max.exe
sugar
Global Moderator
Global Moderator
Post by sugar »
Latest version
18 / 19.0 Beta 4 (February 22, 2024)
New :
* The playlist editor has received support for multiple playlists
that you can instantly switch between. Multiple playlists are
loaded in a background thread so even if you use massive
playlists with 1000's of items, it should not have much of an
impact Zoom Player's load and close time performance.
Press the new multi-playlist button on the playlist editor (top
left corner) to add the current playlist, a playlist from a file
or manage the multiple playlists (remove, rename, reorder).
You can see me develop this feature live here:
Part 1 : www.youtube.com/watch?v=6hhQoJ0kkoA
Part 2 : www.youtube.com/watch?v=2GLUuymiz_Y
* New "Cast to Device" feature on the main right-click menu and
available as a keyboard shortcut (Shift+"/") that allows you to
Cast the currently playing media to a Chromecast compatible
device. This feature does requires libVLC is installed but does
not require you to play the current media with libVLC (the
playback engines automatically switch as the media is casted).
www.youtube.com/watch?v=A3eDBtunqZc
* New "1510" Zoom Player API message that is triggered when using
next/previous chapter. Returns the chapter's position in seconds
Fixes :
- Fixed a bug that caused the background image to show for a split-
second when dragging & dropping a media file on top of the player
window.
Download Zoom Player 19.0 Beta 4
https://www.zptechnology.com/download/zp1900b4max.exe
sugar
Global Moderator
Global Moderator
Post by sugar »
Latest version
19.5 (August 28, 2024)
What's new in Zoom Player v19.5:
* IPTV Xtream Codes support.
Zoom Player supports three different Xtream Codes modes to access the stream playlist and EPG (electronic program guide) information. The modes exist to offer a fallback solution in case your IPTV provider is only offering partial support for Xtream Codes' feature-set. 1. Player API : This is the most recent Xtream Codes API. It uses network queries to obtain both the Stream Playlists and EPG data. TV Series and Movies are handled separately from live streams, providing an enhanced navigation experience.
However, the EPG information is only accessible on a per-stream level and not as a whole, preventing the Global Filtering and EPG Grid features from working. 2. Player API + XML (default) : By leveraging the Player API you still benefit from the separate handling of TV Series and Movies. With the entire EPG downloaded as a single XML file, the Global Filtering and EPG Grid features have access to the full program guide and can work as intended.
3. M3U + XML : This is the most basic mode with both the EPG and the stream playlists downloaded as single-file databases. Global Filtering and the EPG Grid features work as intended, however TV Series and Movies are left to the graces of your IPTV provider, which means they may be harder to access and usually lack EPG or Meta-Data information (e.g. Bitrate).
* New IPTV Electronic Program Guide Grid. The EPG grid is an alternative program guide view that lists the episode guide of multiple streams in an easy to scroll and filter interface.
You can access the EPG grid by pressing the "#" button within the IPTV window. The EPG grid does not rely on the stream list and can be used without specifying any stream sources. The EPG grid's look and feel can be fully customized by pressing the menu button and choosing "Customize". You can use this same menu to "Magnetize" the EPG Grid window to the IPTV window.
* New IPTV global episode guide filter. The new global filter works across all streams, filtering out streams that do not contain a program title containing the filter text. Global filtering is very useful when searching for a particular program or live event across all available streams. Please note that performing the initial global search triggers a one time stream indexing operation that may up to a few minutes on some hardware.
* Added support for H.266/VVC, AV1 and Opus detection and icons to the media library.
* New IPTV menu button on the IPTV window. The new menu includes: 1. Only show favorites (new feature, hides all other streams). 2. Toggle Opacity (previously a button). 3. IPTV Settings (previously a button).
* Added a new setting (Adv. Options / System / Screen Saver & Capture) that allows you to specify if screenshots should be saved in the same folder as the video currently being played (Only applies to local files).
* Added a new setting (Adv. Options / Playback / Video / Aspect Ratio) to reset the aspect ratio to "Derived" when opening a new media (disabled by default).
* Added a new setting (Adv. Options / Playback / History) to automatically restore the previously active video aspect ratio on replay (disabled by default). This new feature will only work for videos that was previously played by this version of Zoom Player (or newer) since previous versions did not save the active aspect ratio.
* New Setting (Adv. Options / Playback / IPTV) to sort the Group list by name.
* New Setting (Adv. Options / Interface / Fullscreen Naviation / Settings) to prevent the fullscreen playlist and streaming navigation interfaces from closing when playing a new file.
* New Settings to seek forward/backward a percentage of the media's duration. Te default seek distance is 10% of the media's duration but you can change this value under "Adv. Options / Playback / Controls". By default, the two new functions are assigned to the Ctrl+Alt+"[" and Ctrl+Alt+"]" keyboard shortcuts.
* New Settings to seek forward/backward a percentage of the media's duration when right-clicking the timeline. The default action is still seeking in seconds, you can change this to percent under - "Adv. Options / Interface / Mouse / Settings".
* Added settings to control which Zoom Player function is triggered when using the mouse wheel while holding either the Alt, Ctrl or Shift keys. The default values are: Mouse Wheel + Alt : Seek 5 seconds backwards/forwards Mouse Wheel + Ctrl : Seek 20 seconds backwards/forwards Mouse Wheel + Shift : Seek 120 seconds backwards/forwards
Watch me code it live:
https://youtu.be/hyEXJgvPv7c
* New Setting (Adv. Options / Playback / IPTV) to control whether global EPG filtering includes filtering using the program's description. This setting can slow down filtering and is disabled by default.
* New "Copy path to clipboard" item on the playlist editor's right-click menu. This feature allows you to copy the file or URL path of the selected media entry in the playlist editor.
* IPTV Per-EPG Time Shift support (Adv. Options / Playback / IPTV) has been added. The time shift is applied to the entire EPG. Please note : If you previously set a time shift on a specific stream then both time shifts are combined.
* In cases where you list an IPTV stream supporting archive playback but the stream does not have an Episode Guide or the Episode Guide does not cover the full archive period specified in the playlist, Zoom Player now creates empty entries on the EPG listing panels to enable archive playback covering the full archive period.
* IPTV playback of streams that require authentication using user-agent or referrer are now supported. For compatibility, Zoom Player uses the same "#EXTVLCOPT" playlist tag as VLC. This feature requires a version of LAV Filters newer than 0.79.2 as it was introduced by LAV Filters in a nightly build released after v0.79.2.
* Rewrote some of the IPTV stream listing code to work much faster when dealing with massive stream lists.
I used a test file containing an outrageous 572,527 playlist entries in a 142mb file. I managed to reduce filtering time from 24.4 seconds all the way down to 1.3 seconds or 1877% faster compared to the previous version.
* Added an IPTV stream "filtered / count" label to the IPTV window.
* Adding an IPTV Playlist or EPG download link will now automatically suggest a profile name based on the base URL.
* New Setting (Adv. Options / Playback / IPTV) that determines whether clicking on an IPTV group snaps the group to the top of the list, displaying the maximum number of items on-screen. Enabled by default.
* Added an "Export Playlist to M3U" feature to the playlist editor's right- click context menu.
* Closing Zoom Player with less than 1GB of free space on the "C:" drive now shows a warning message. Under some conditions, low disk space can corrupt Zoom Player's settings and we don't want that. If the message is annoying, disable it under "Adv. Options / System".
+ Some of the IPTV customization options have moved to an interactive dialog that can be opened from the IPTV window and allows you to view any changes you make in real time.
+ The media library now shows the media's duration in list view mode when a duration is available.
+ Cleaned up the Advanced Options dialog's Video Aspect Ratio section.
+ Cleaned up the Advanced Options dialog's Mouse Wheel section.
Watch me redesign it live:
+ Redesigned the chapter/bookmark editor to make it cleaner and easier to use.
+ Enhanced the IPTV playlist parsing code to be more tolerant of badly authored playlists.
+ Optimized several parsing functions, Zoom Player should now load a little quicker.
+ You can now edit the IPTV's Playlist/EPG URL value without having to first remove the existing listing.
+ Unassigned (to a group) IPTV playlist entries are now listed on the bottom and not semi-randomly (where the first unassigned entry was spotting in the playlist).
+ Zoom Player no longer asks you if you would like to add the free IPTV channels if you already configured your own IPTV subscription service.
+ Clicking on a playlist entry in the playlist editor window when search is active, now removes the keyboard focus from the search box. The search value is not reset in this case, just hidden until you click the search box again.
+ Changed the title of the IPTV interface on the right-click context menu from "IPTV Electronic Program Guide" to "IPTV Player".
+ Some of the IPTV window's buttons have moved under a Menu button to make room for new features.
+ The Media Library's YouTube Playlist plugin can now be used to "Refresh" the thumbnail and playlist name under the media library editor's configuration page.
+ For clarity, the IPTV Window's "Play Stream" button is now disabled in cases where streams can't be played based on the currently selected entry.
+ The scene-cut dialog now closes when closing the playing media and will not open unless a media is playing with a duration longer than "0".
+ The "Reset user interface windows" function now applies to the IPTV player window and EPG Grid window.
+ Refreshed the content of the keyboard help dialog (F1 keyboard shortcut) for clarity.
+ The options dialog's Search feature now tries to screen-center the searched feature when clicked.
+ You can now select and delete multiple media library categories in the media library category editor using a single action.
+ You can now use the "Delete" key in the media library category editor to delete (with confirmation) the selected categories.
+ Added a right-click menu to the media library category editor's category list to make the features more accessible.
+ Small tweaks to the Media Library Category Editor layout to i...
https://www.videohelp.com/download/zp1950max.exe
Latest version
21.4 (May 26, 2025)
What's new in Zoom Player v21.4:
New :
* New Setting (Adv. Options / Playback / Media Server) that determines whether to list collections alongside categories in the Media Server Browser (PLEX / Emby / Jellyfin).
* New Setting (Adv. Options / Playback / Media Server) that determines whether to list collections within categories in the Media Server Browser. This feature is limited to PLEX as it's the only media server that associates collections with a specific category.
* When creating a new category, the Media Server media library plugin will now list Emby/Jellyfin collections. Emby/Jellyfin collections are not locked to a specific type (e.g. movies/tv) so every collection is selectable, regardless of the category type you are creating. This feature can be disabled in the plugin's configuration page.
* When creating a new category, the Media Server media library plugin will now list PLEX collections based on the category type you are creating. Unlike Emby/Jellyfin, PLEX locks collections to specific categories. This feature can be disabled in the plugin's configuration page.
* The Media Server media library plugin now lists PLEX collections within categories. This feature can be disabled in the plugin's configuration page.
Changed :
+ The IPTV Setup wizard has been enhanced for clarity and includes new Information, Skip and Quit buttons.
+ When using the media server browser interface, going up a folder now restores the exact position of the list prior to entering the folder (the list's top index is now saved along with the item's index).
+ The MP4 and Matroska (MKV) smart play profiles have been split in two. Each format now has two smart play profiles, one for local file playback and one for streaming, allowing you to pick different components depending on whether you're playing a local file or streaming from a media server.
+ The Media Server Browser's pop-up hint that appears when hovering items is now a lot less annoying. The hint will only show when hovering over items that don't have enough space to display and instantly hides when hovering over other items.
+ Emby/Jellyfin collections are no longer listed as a "Collections" folder, this has been replaced with the collection setting above.
+ Updated MediaInfo to the latest version.
+ Small quality of life enhancements throughout the UI.
Fixed :
- When moving Zoom Player's window between monitors should no longer pause or snap the window back to the original monitor.
- Zoom Player will no longer adjust the minimal window size based on your monitor's resolution as it broke some features. This does mean there can be some visual artifacts as the control overlay gradient backgrounds may overlap each other if the playback window is tiny.
- Right-clicking a media library entry did not select the entry unless it was in a TV or Movie category.
- Fixed a case where another Zoom Player window could appear between the main player window and the control overlay.
- The Home Theater quick search feature was partially broken.
- The quick search feature now works on with both media file/url or title in the play history Home Theater interface.
- When using the YouTube IFRAME player with the Chromium engine it was possible that seeking ahead/back multiple times in a row in under 250ms would seek in place.
- The trial version of Zoom Player MAX/IPTV no longer asks you to upgrade on first run.
Download
[SHOW POST]
https://www.videohelp.com/software?d=zp2140max.exe
